2009 Yukon Denali fender flares
eman8
Hi all,
Does anyone know if there are fender flares for an 09 Yukon Denali? I’ve had no luck searching online. I have only seen fender flares for the non Denali trim. I’m trying to cover body rust around the wheel well.
Thanks,
Eric
Hi all,
Thanks,
Eric
Never seen any. The issue is the shape of the rear bumper cover. Put a regular one on and then you can use them. If you have Side Blind Zone Alert, make sure the donor includes those mounts. SBZA became available on non-Denali Yukon and Tahoes from 2010-2014. Careful though, the later LTZ Tahoes have the same rear cover as yours.
Matthew Jeschke
Sahuarita, Arizona
I'm not sure the factory made any for that version of the Denali. I believe your inner fenders are attached a bit differently than the previous body style too. Not sure how they would attach? Sounds like @swathdiver knows...
I couldn't find any for my 2001 Tahoe. Had to finally go to the junkyard where there's TONS of them. This did also mean I had to paint them to my color, which was pretty easy honestly. I did it myself.
Durobans
