2007 Tahoe - Cruise Control Stopped Working
txaggie929
Have a 2007 Tahoe 5.3L 4x4 w/ 57K miles. Cruise control has stopped working overnight. No intermittent problems, just quit working period. Switch turns on light on steering wheel, but not on dash.
I have already checked the fuse and replaced the stop lamp switch with a brand new AC Delco switch, and cruise control still will not function. Hoping this is not the body control module going out.
Anybody have a similar experience? Any insight is appreciated.
T
txaggie929
We use the parking brake multiple times a day, no hang-ups or broken cables. Read that other link and it describes what I've already fixed - thanks for the info though.
Anybody else got any ideas?
Ben
PCB, FL
I had that happen to me one time the parking brake wasn't released all the way and it kept the cruise from engaging. Sometimes is the simplest fix. Kinda sucks, I know its a annoying just keep trouble shooting.
badzr1
Besides the ebrake check, if you have the adjustable pedals cycle them once or twice and see if that helps. It worked on mine.
T
txaggie929
It does have the adjustable pedals, and I cycled the pedals through a full range of movement several times. Still no dice.
jherbst777
Brake Switch - part 25981009. Only cost's about $20. It is a switch underneath the brake pedal that tells your cruise control to shut down when you tap it. Apparently its common for these to go out. I bought one to fix my '07 Yukon Denali and was told to move the existing one around before taking the time to fix it. Well it worked and has for a month now. I just kept the switch so I have it available to replace when needed.
T
txaggie929
Thanks for the replies about the stop lamp switch, but like I said in the 1st post of this thread, I already replaced that switch and it still did not fix it.
DeSexingStick
