2007 Tahoe: 305/50-20?
JTS
Ontario, Canada
Tried the search engine - apologies if I missed this if it has been asked.
Thinking of keeping snows on my stock 20" rims and buying 20"s or 22"s for the summer. Will 305/50-20 tires fit w/o rubbing? Don't want to do any cutting to make it work.
If anyone has 305/50-20, please post pics.
Thanks in advance.
nytahoe
"Tha Butcha"
new york
i think its going to rub a lil bit 32"tall and say a 305/35/24 is 32.4 tall and that what a lot off ppl run
Conor
"Bob's your Uncle"
Seattle, WA
Thanks John
Jenna Bear is running that size tire if I remember correctly. They will rub pretty bad with OEM 20's, but with aftermarket wheels I dont think you will have any issues. If you are running OEM 20's, I would go with a 285
nytahoe
"Tha Butcha"
new york
yea also very tru cause of the with of the rim on a 20x 8or 7.5 what ever the stock rim with is the side wall will bowe out more then a wider rim
JTS
JTS
Ontario, Canada
I will get aftermarket rims for sure (keep the OEM rims for the snow tires).
Looking to find the correct offset so the tires really fill out the wheel wells but don't stick out.
will check out Jenna Bear's truck
thanks
dizhai
