2007 Burb radiator change. Tips, tricks, timesavers welcomed....
Kapitein
The Netherlands, Europe
Hi folks
In 4 days time I'm due to leave on a 3000mile roadtrip towing a 5000lb camper.... Of course the radiator has chosen this moment to retire itself from active service.
It's an 07 Burb 4WD with the 4L60 and the GT4 RPO code.
I've immediately ordered this from Rockauto:
GM 21726
I'm based in Europe, so as long as DHL are on time, the part should come in on Wednesday.... I can't get any shop time with this short notice, so I need to change it out myself... Probably Thursday morning before we leave Thursday afternoon .
I've watched a few YT videos and it looks straightforward enough, but are there any gotchas, or time saving tricks etc you can offer from experience.
I need this to go right 1st time, otherwise the family summer vacation is screwed.
Thanks in advance :)
j91z28d1
I've not changed mine on this truck, but in general I'd say check that you have the right size tools to get to and loosen the transmission cooler lines. may go ahead and make sure you can loosen them now while you have the time to run to the store. they just snug back till the day of.
good luck. hopefully shipping goes well.
mikez71
A pick can pry off the transmission line clips. There should be new ones with your new radiator in case they fly away.
The radiator hose clamps have a little tab that limits how far you can open the clamp. Makes installing the hose/clamp over the bump a little tougher.
You can bend the tab for more clearance if you're unable to use the tab to latch the clamp open.
Otherwise very straightforward. You will succeed!
Geotrash
Dave
Richmond, VA
Hi folks
GM 21726
Super easy job - should take you no more than an hour. Remove the top cover over the cowl. Remove both radiator hoses and cooler lines along with any other lines attached to the radiator. Remove the fans (unbolt the top 2 bolts, release the wiring connectors, and pull the whole fan assembly straight up and out. Plus the radiator up and out, and reverse for install. Make sure the new radiator comes with grommets for the pegs on the bottom and if not, make sure to keep and reuse your originals. While you have everything apart and the system drained, replace your radiator hoses, heater hoses and connectors at the firewall. Might as well replace the thermostat too.
petethepug
Michael
SoCal
You’ll improve the coolant flow and this leads the plastic fittings at the heater core lines to crack and burst.
Order the Gruven repair kit or new OEM lines next chance you get if you haven’t already done so. To cover yourself until then purchase a couple of bolts that will fit the inside diameter of the heater hoses and a couple of hose clamps. Put them in a bag with a pair of side snips and screwdriver in the jack storage area.
Those pesky heater hose line will drain the coolant in less than 45 seconds forcing engine shutdown while in motion. If you’re on a grade or mountain it’ll turn your hair white. No engine power at speed loses power steering and power brakes. These beasts DO NOT stop or steer worth a damn without the motor on.
Foggy
KS
Install is straight forward.. But make sure when you are done that you properly
bleed/burp the cooling system.
It may seem "OK" but you don't want to get on the road and find out you
have air in the system.. you will overheat in matter of a few minutes and your temp
gauge won't help/be accurate
me51
Germany
I have read about a spacer or restrictor in the line going to the overflow tank, if it's missing you are likely to get coolant warnings so make sure you transfer it to the new one: https://www.tahoeyukonforum.com/threads/what-is-the-best-radiator-available.125918/#post-1560401
Bleeding the cooling system on these is not too difficult. Fill the system slowly through the tank up to the mark, install the cap, start it on level ground and run it at a little more than idle speed until the coolant has been at 90°C / 194°F for at least three minutes and then turn it off. Let it cool down and check the surge tank level and add if necessary, I had to add about a 1/4 liter if I remember correctly. I also like to check the heater output, if the system is bled correctly you should get good heat coming from the air vents in the interior.
You can either buy the expensive orange Opel/GM Dexcool or any other coolant that is compatible with GM 6277M.
Charlie207
LFOD, New Hampshire
You can take a spent .45ACP case, and drill a 1/8" hole through the primer pocket, to use as the flow restrictor. The diameter of the spent case is about a thick blonde one oversized from the ID of the return hose, and fits perfectly inside. Use narrow flathead screwdriver to push the case a couple inches into the hose.
I know this works because my Champion radiator didn't come with a restrictor, and I couldn't get the old one out of the leaky radiator. My coolant temps weren't rising at all prior to the Billy Dee Willams mod. (See post HERE)
Foggy
KS
You only need to do that restricter when you use an aftermarket upgrade performance
radiator like the all aluminum cold case radiators... NOT a stock replacement radiator
Just install it !!!
Kapitein
Kapitein
Thanks for all the insights. Sounds like it should be a straightforward job....
I just need the darn thing to arrive. As of right now it's still in Santa Ana California and I'm a continent away :(
Geotrash
Dave
Richmond, VA
It's in! Thanks all.
Depart on vacation tomorrow. First time towing with this rig. So far so good, covered about 150miles today on flat ground.
Yeah, that radiator was due. :)
And that might be the largest caravan I've ever seen on that side of the pond. Nice! The Suburban makes the perfect tow vehicle.
dizhai
