2005 Z71 radiator replacement recommendation
Bocephous
I just joined this forum a short while ago and left an intro in the introduction section. I'd like to replace the (as far as I know) original radiator in my '05 Z71 5.3L to prevent future problems. 242,000 miles on the motor and it runs great, but the Tahoe is our back-up vehicle, not a daily driver. The previous owner, a good friend, performed a lot of work on this as he had meant to keep it but plans changed. I'll provide a list of what he performed. What are your recommendations for a new radiator?
The original (?) OEM radiator lasted for 242,000 miles, so why not replace it with the same radiator? You can get good reduced pricing at RockAuto.com and at GMPartsDirect.com.
Marky Dissod
20 years ago, things were manufactured to a higher standard, especially for brand new vehicles.
I HOPE OE for a 20 year old vehicle still means what it did 20 years ago, but I am not an optimist.
When you are doing maintenance replacements, it's ok to upgrade, if the price is right.
While you're there, very seriously consider replacing the rear HVAC coolant Y & T connectors.
Even if you feel froggy enough to not replace them in advance, buy them now, &
keep them in the glovebox for when they do fail.
Matthew Jeschke
Sahuarita, Arizona
Did you get it figured out? I've had my eyes on this guy HERE for a LONG time. One of my buddies purchased a radiator from them for his square body build and likes it. Stupidly I just swapped in a factory radiator when mine went out and 50k miles later along with multiple upgrades since...
When I startup my truck and let it and warm up to temp I get the following temperatures.
Upper hose 178F
Lower hose 165F
I measured my friend's stock 2005 Z71 and the upper hose was a similar temp (178F) but the lower was like 115F. I'd say it's 20% humidity, 85F ambient, and 2500ft when I took measurements.
Maybe I'm maxing it out my radiator?
Backstory:
I did some cooling system upgrades HD GMT900 eFans and most recently I installed a 180F tstat. I have a new radiator as mine gave out around 225,000 miles (not sure if was original, seemed so but I'm not original owner of truck). I have a built 6.0L swap in my truck. I think they all came with the same radiator though?
Montana _Tahoe
Montana & Arizona
Just recently My 04 Tahoe LT radiator decided to spring a leak at 215k. I replaced it with an OEM unit from AutoZone. I did the E-fan upgrade using an Escalade fan which does a great job.
B
Bocephous
Upper hose 178F
Lower hose 165F
Backstory:
I ended up replacing it with one from Rockauto, I'm pretty sure. Being a backup vehicle, she only sees maybe 1000 miles a year.
Charlie21ny
