2005 Yukon Denali Shock Torque Specs?
kna4977
I just replaced the factory shocks on my 2005 Yukon Denali and need the torque specs for front and rear top and bottom bolts/nuts.
Fless
Moderator
People's Republic of Colorado
2wd or 4wd?
From Haynes
Front:
Upper nut: 15 ft-lbs
Lower bolts 2wd: 19 ft-lbs
Lower bolts/nut 4wd: 59 ft-lbs
Rear: (2005 & later)
Upper bolt/nut: 15 ft-lbs
Lower bolt/nut 2wd: 18 ft-lbs
Lower bolt/nut 4wd: 59 ft-lbs
K
kna4977
2wd or 4wd?
From Haynes
Front:
Thanks it's a Denali. All 2005 Denalis were AWD. Seems like I remember but can't find it that the upper and lower in the rear were the same spec??
Ed Sievers
Replying to an old post here ..... with r e a l data, FYI. Hope the file loads and hope you find it useful.
Ed Sievers in Denver, CO '15 Yukon Denali 4WD
  • Yukon Brake Job Torques.pdf
D Rollins
