Alberta Tahoe
- Joined
- Apr 25, 2015
- Posts
- 196
- Reaction score
- 63
I started a thread about adding Sea Foam via a vacuum line to address a undoubtedly plugged PCV system. Among other issues.
www.tahoeyukonforum.com
Now I'm pursuing what appears to be a popular fix for a common problem on several iterations of the LS engine including my 2005 LM7. That being upgrading to a newer version of the drivers side valve cover.
I was directed to a TSB although it doesn't include a 2005 model nor an LM7.
So, as I continue to search, I'll ask here. Does anyone have a part number and a procedure that's the most current?
By procedure I don't mean how to remove a valve cover but rather any other modifications required, such as grommets, updated PCV valves or fixed orifices needed to complete the upgrade. The best I can come up at this time is GM's 12570427.
Thanks in advance.
2005 LM7 and Sea Foam
My 05 Tahoe, with a previously poorly maintained 200 000 mile LM7 is a oil burner. And a leaker too. Before I pull the valve covers and address what is probably a valve guide seal issue I'd like to try the Sea Foam vacuum trick. Looking through ALL of the online tutorials it seems that the...
Thanks in advance.
