2003 tahoe
Okierock1959
When I shift the transmission from park to reverse or drive, there are a series of dings. It is not constant, and varies from 3 to 15. What would this be? A code for something needing attention?
rockola1971
Indiana (formerly IL)
Id check the U joints on the rear driveshaft first. How many miles? The U joints original or been replaced with aftermarkets and have the clips?
Matahoe
Military
Grand Rapids, Michigan
Is the check engine light on? Electronic dings from the speakers usually indicate something is being disabled after failing a test such as the brake system for stabilitrak or traction control. usually it is noted on the DIC.
O
Okierock1959
rockola1971
Ahhh I just comprehended the "dings" you were hearing were across the stereo system. Take a look at your instrument cluster below PRNDL indicator. Should have some mesages there for you telling you whats up.
O
Okierock1959
Thanks
