2002 Tahoe LT 5.3L ABS Wheel Speed Sensors
JimmieT
Trevor, WI
New to the forum, lots of great post! So I went to pull the front ABS wheel speed sensors on my 2002 Tahoe, that I bought a few weeks back, due to the ABS light always coming on shortly after starting. The problem is the bolts that hold the sensors in are completely rounded out. I can’t get anything to bite. I was wondering if anyone knew the actual size of bolts (thread/length), so I can just extract and replace? Thanks for your time!
mattbta
Frisco, TX
How many miles? Might be time/easier to replace the entire hubs with some Timkens.
Welcome to the Forum from NH.
Pics of the truck, please.
Other more knowledgeable folks then me on this Forum will chime in.
corvette744
2004 Z-71
Northern illinois
If you havent or previous owner has not changed the hub bearing assy i would do that for sure.Would suck to have to go back in it to change them again.If you can take back your sensors and get your money back i would order new hubs come with the sensors in 4wd or rwd.https://www.partsgeek.com/ss/?ssq=timken&make=chevrolet&year=2002&model=Tahoe Shop around online seen them for 81 bucks on ebay Shipped to your door.
Teamiez
100% agree, my light came on around 150,000 I think and tried just the sensors, turned out to be the wheel bearings tripping the light. Never knew those hubs were that fancy. Ended up doing 2 jobs and wasting money.
Hobert
Downers Grove, IL
If you haven't or previous owner has not changed the hub bearing assy i would do that for sure. Would suck to have to go back in it to change them again. If you can take back your sensors and get your money back i would order new hubs come with the sensors in 4wd or rwd.https://www.partsgeek.com/ss/?ssq=timken&make=chevrolet&year=2002&model=Tahoe Shop around online seen them for 81 bucks on ebay Shipped to your door.
Same here my 2001 Yukon XL front hubs replaced twice for same issue. 1st set around 130,000mi 2nd at around 240,000mi
mfinta
