2000 Suburban 1500 LT Interior lights quit working
Stimpy911
I was in the process of running wires for my EMS Emergency Lighting and now my interior lights are not turning on either with the switch or when the doors open.
I have checked the 10 amp interior fuse and replaced the relay under the driver's side console.
Is there anything else to check?
Thanks
Sent from my moto g(7) supra using Tapatalk
S33k3r
Dallas, Texas
I have not experienced this problem myself, but I DO have some suggestions: Check all the areas associated with your new wire runs. As part of that, check all the fusing of your new system, and use a tester in addition to your eyeballs. A fuse can be popped and not be obvious to the naked eye. Finally, check the fuses under the hood. I had one blown there that took out my cab marker lights.
S
Stimpy911
Is there a fuse under the hood to be checked? Which one is it? Also, is there a ground somewhere I should check?
dizhai
