2 Yukons with bad transmissions
When did you experience transmission problems?
  • Total voters
    30
02n12
I just got my Yukon back after $3500 worth of transmission repair. What are the chances? I've had 2 Yukons (2002 and 2012) in the past 17 years and they both experienced the same problem. Both transmissions went out around the same mileage, about 150K miles!!!! The repair shop said XL version was brought in for the same issue while mine was being repaired, similar model year and color as mine too LOL
Have others experienced the same type of issue?
I replaced my 2002 with a 2012 and upgraded to 4X4. I've always taken care of my cars and have had other foreign makes and models last me much longer without these type of issues. I've always like the design of the Yukon over other SUVs, but this will likely be my last. With both, I've had too many major repairs besides transmission issues and other quality issues too. They've cost me too much money to own beyond purchase price.
The only reason I repaired this 2012 is because I'm giving it over to my teen son to take to college and finish running it to the ground. Hopefully it will last a couple more years before another major issue happens. Oh, but I already have something I should probably repair, bad driver side motor mount.
wjburken
Eastern Iowa
The transmission on our 2007 got replaced at 160K. Put a GM certified transmission in that came with a 100K warranty on parts and labor. Still going strong when we traded it in at 300K. Wish we would have kept it in retrospect.
trailblazer
Did you buy these Tahoe’s new? Did you change the trans fluid and filter out every 30-40k? A 4L60E and 6L80E are hydraulic dependent systems that require an extremely clean operating environment. Also, exposure to extreme temperatures, even briefly, can have severe consequences. Several years ago I worked as a medical contractor at Chrysler Proving Grounds. I was nosey and bored and bothered the staff a lot. They would let me hang around when they worked. The Mechanic-Engineers could “shred” a transmission in about two minutes. Even the bulletproof Mercedes G56 or ZF S6-650 manual would die after three hole shots. These guys were literally pro’s at destroying powertrains but it doesn’t explain why you’ve been so unlucky. I’d say it is mere coincidence.
Fless
Moderator
People's Republic of Colorado
You should add a "never" selection, but then you'd want to qualify that with mileage categories.
Never with mine, 104,900 miles on the clock. Fluid and filter change at 95K. Did I just jinx it? LOL
adventurenali92
Big Bear Lake, ca
GM’s transmissions are a known weak point in the drivetrain. That being said I’ve seen a lot of guys here say they are still on the OEM transmission at or near that age, with regularly scheduled maintenance done on them and no problems. So if you stick to the scheduled maintenance on them they can last. My 4L65E died at 86,000 because the previous owner beat the snot out of it and never had it serviced. I’m three years into a rebuild and haven’t had any problems with it. It’s about time for a fluid flush and filter but that’s expected.
BG1988
The engines Require Extremely clean oil too, Active fuel management
train wreaks on dirty oil.. you can't getaway with it like the non AFM engines....
that is why you always inspect the 8itch i mean hitch and ask if it was used for towing
towing = heavy wear and tear I would pay less on one used for towing minus 2500-3000 on what they are asking.. inspect for repaint on it ....
for towing the oil should be changed every 4,000 miles (unless you get a larger filter ) and 15-20k on the transmission
unless you get a after market setup for the oil (i.e larger oil pan)and transmission filtration..
also an oil and transmission cooler upgrade..... remember you want to keep the temps at NON towing temperatures...
I never hit above 165f in the summer and 145f in the winter on the transmission
02n12
2002 Yukon had 8K miles and 2012 was new off the lot. Tran fluid changed and always serviced by dealer for most work except for a set of brakes and some engine oil changes. I do pull a boat several times over summer but well within tow limit.
gat0r
DFW
you are missing the option in your poll for: not yet
no issues...yet on my '15. about to roll 60k on odometer.
im sticking w/ the severe maint. chart intervals. so far, so good
Jeramia
Foley Al.
I bought a 2005 Tahoe new (still have) I changed the oil and filter at 30-60-90 thousand miles. Trans went out at 110,000 So the oil changes that I did was a waste.
But why did it go out? Always overhauled my own trans, before but getting to old to crawl under the car. Had Chevy install a rebuilt..
I think it was just one of the valves, or celenoid in the valve body hanging up. I will never know.
Patrick P
I have a similar experience. I had 2004 GMC Yukon that I ran for 450k miles... and 3 transmissions. The problem was resolved when I stopped using GM parts, and replacement transmissions. I live in SoCal and took it to Leon’s transmissions. These guys are fantastic by the way. They know their transmissions. They said these transmissions are the most repaired transmissions out there. The issue is their Torque converters. Leon’s overbuilt the transmission with better grade after market parts that address the issues with these transmissions. The transmission that Leon’s built worked better than the original transmission the vehicle came with and lasted until I wrecked the vehicle. Now to present .... I purchased a 2017 GMC Sierra 1500 and had the exact same issue at 50k miles. Still under warranty I had it repaired at a GMC dealer here in La Quinta..failed Torque converter, burnt clutch, metal shavings thought the oil and pan.. we’ll the issues of hard shifting, which is the beginning of the problems, still exist. I took it back and they couldn’t replicate the problem.... BS.... they are kicking the can down the road. There are fixes for this problem as I know first hand. GMC warranty won’t allow any after market parts to be used that are not GM parts, so says the service manager at the dealership in La Quinta. There’s the problem. We can put a man on the moon, but CMC can’t make a transmission that works. I have had. 8 of their vehicles in my life and never had a transmission issues on any of them except the last 2. This will be the last GM or Chevy product I own. The good news is there is a class action lawsuit against GM for being unwilling to fix the problem. GM doesn’t make money in selling cars anymore, they make money on service at 150.00 an hour.... GM should have been allowed to go bankrupt in 2008 and 2009 it would have been purchased, reorganized and today consumers would have a better product. Bailing GMC just saved the old ways of doing business and the unions that as we know now are corrupt. They just lost a loyal customer
02n12
Yup. Torque converter was the culprit on mine as well. Kosub Tansmission near San Antonio Tx said the same thing about these transmissions. They replace the torque converter with a better aftermarket version. Hopefully it will last long enough for my son to get through a couple years college.
JonnyTahoe
Minneapolis
Towing may be part of the problem. My '00 Tahoe went 295k mi. Have complete history on truck from original owner with all service records since new. Towed a Trailer to Chicago one time and a snowmobile a few times. Had fluid changed at the dealer recommended 30-60-90 intervals and changed fluid a few times myself. Trans shifted poorly for the last 50k mi. Drove around in 3rd gear mainly unless on the highway to prolong trans life. Internal parts failure not the converter seems to be what happened in my case.
BG1988
These Transmissions are shifting Hundreds of times each day and can last over ten years. Try pushing your truck up your driveway let alone 150k mi.
sounds like something would create a ton of heat
Heat = bad
Less heat = good
Less heat = longer life
more heat = shorter life
at 145F we can expect a life expectancy of 200,000 to 250,000 miles or more
at 175F we can expect a life expectancy of 125,000-150,000 miles(or more if your lucky)
you have to drive about 1/2 hour with the hybrid to even reach operating temp... it's the reason why they last to 250,000-300,000 miles... plus they cost 10k a piece (initial building costs )... if it failed before then it's "Operator Error".. there is no thermostat on the transmission cooler line
mo2058130
OT - I have a new to me 05 Yukon XL, 2wd will be used for light towing. If and when the tranny goes which a better option. upgrade to a 6L80e or stick with the 4L60e and get the upgraded torque converter.
Also when going with a larger tranny oil pan is there a larger filter that goes with? Will that upset the pressures at all? Thanks!!!
RB_Trucker
Redondo Beach
I had a 2004 Yukon Denali AWD with the original trans @274k. Fluid was always changed at the proper intervals, never towed and shifted beautifully. Sometimes your just SOL with vehicles.
sealandsky
Minneapolis, MN
IMOH, they are designed to last about 100K miles so you did well.
02n12
Living in South Texas maybe putting a temperature gauge on transmission should be factory installed or something. Or if they're only intended to last that long setting expectations would be helpful. I would not have bought them if I had known.
Oh well, it is what it is I guess.
AZPatriot1963
