1998 tahoe LS swap
2drhoeon4s
got a little bit more done... It is getting closer.
I ordered my PS hoses, heater hose, radiator hoses, serpentine belt, maf and coil plugs, ECM connectors, and a few other things..
Side note. does anyone have any multec 2 plugs laying around? Il paypal you some dough for them!!!
My headers came in!!
I am starting to fab the bracket to move my 411 ECM to the drivers side now that I am using my original harness
Got some wire to add to my harness..
Working a little at a time on my harness... I have all the connectors mostly labeled..
SwampHound
Alabama
Looking good man! Headers match really well with the rest of the engine
Sent from my XT1080 using Tapatalk
2drhoeon4s
seems like user error on your part.... everyone else seems to be able to see them.
2drhoeon4s
sunlit.. you have been on teh interwebs for hundreds of years... figure it out please... haha
I didnt do anything... I saw what you posted, typed a reply, and went to work.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I think it is your hosting server. Unless the pic comes thru without needing to re-send data in the event of packet loss they wont show. TYF seems effected by it too. Earlier their was just text with large space gaps. no photos. not even broken link indications.
Paul-ish
Cool build, I plan on doing this in the near future...
Wiring it looks like a nightmare though...
Nak
Very cool. I'll start on mine in a bout a year hopefully. Gotta get one more emissions test done then I'm through with them! :)
Why did you mount the ECM on the passenger side instead of the stock location? Just trying to get as much info as I can before I do mine... Thanks!
2drhoeon4s
ecm was on the pass side because I was buying a premade harness that was designed to feed that way... plus I was going to piggyback with my stock ECU for ABS.. But I changed my mind and decided to wire my own harness and i am in the process now of removing my factory ECM and mounting the new one on the drivers side.
2drhoeon4s
updates.... I got all of my pigtails in except the injectors... Nelson performance said they would email me a tracking number but that was 3 days ago... so i guess we wait..
I pulled it outside and worked in the driveway today.. it was nice out...
Got my fuel lines hooked up, radiator hoses and intake installed. Battery mounted. plug wires..
2drhoeon4s
got the ECM mounted and harness partially installed.. I have a few more plugs to extend...
SunlitComet
OBS Jedi-Do Good
man, you and your randomly working photos.
---------- Post added at 10:31 PM ---------- Previous post was at 10:29 PM ----------
weirdest part this first try is that it is not like it shows a broken link or photo error, it just does not show any sign of it. first had blank pic frames and then after reload nothing at all. Let me reload again here.
---------- Post added at 10:50 PM ---------- Previous post was at 10:31 PM ----------
well only the last pic in your last post shows. all the other including your post before last are empty pic placards.
varminpoolteam
