ExEvolution
- Joined
- Apr 23, 2011
- Posts
- 10
- Reaction score
- 0
I installed an aftermarket Sony stereo, checked and double checked my wiring and everything is correct but the rear door speakers will not work. When I take the speakers out of the car and plug them onto something else they work fine. On my old car (Cadillac devil 1992) it hand a factory amplifier which I had to bypass to get it working with the speakers so I thought there may be some unknown amplifier in this car that I can't seem to figure out. The rear hatch speakers are blown (the conductive thread wire has torn on both of them but it will work if I manually connect it) so front and rear speakers work only the rear passenger doors are giving me issues.
Edit: After a bit of poking around I found a small metal box under the driver seat with wires running to and from it in a single harness. The colors of the wires match up with the rear speakers. If I bypass this box I'm assuming my speakers will work fine after this so I'm gonna splice. Does anyone know which colors belong to each speaker on the speaker side of the box? can I just run a wire through the harness as a passthrough
That is the factory amplifier standby for a wiring diagram.
