any luck on this, i have push button 4x4 too, 1997... fuse keeps popping.. I replaced the front diff actuator and it engages fine, and i could use it for a few minutes then the fuse blows... I also replaced the transfer case cuz i busted the old one...
---------- Post added at 11:13 PM ---------- Previous post was at 11:07 PM ----------
trav, heres what mine does, place trans in nuetral, when u hit 4 high you should here a click and the 4 high light will light up, when it does you're in 4 high and can shift to drive. to select 4 low, put trans in nuetral, push 4 low, transfer will clank, and you'll also here the click, if you dont here the clank it means your actuator on the transfer case is bad assuming the fuse is good and there is no elctrical shorts. That actuator is more expensive then the 60 dollar one that goes on the front diff..
