12V Outlet Power cycle when driver's door is opened
wcorbit
I have a 2021 GMC Yukon Denali with an issue that the dealership is unable to resolve.
I have an accessory plugged into the center console, 12V outlet. The outlet power cycles, when the driver's side door is opened, which requires me to manually restart my plugged in accessory (which is annoying). This happens, when the vehicle is running, so should be un-related to the power-off delay. It only appears to occur with the drivers side door, not any of the passenger doors. I have automatic running boards, which deploy at the same time, and can hear a relay clicking beneath the center console armrest at the same time the power goes out (related?).
The dealership tech informed me that this is a "safety feature", and that nothing is wrong with the vehicle, however, my gut tells me that they are wrong.
Anyone have a similar experience? Does anyone know if a process exists to escalate this issue to GM, directly (in case the dealership is wrong)?
TIA
TrueAt1stLight
Minneapolis
Huh. I think I’ve got this same issue on my Denali. I’ve got a Valentine V1 radar detector plugged in to that outlet and it will power off and back on when the door is opened. Now that I think about it, I’m not sure if it’s off with the door open and back on when closed or if it cycles through start-up with the door open. I’ll report back with my findings.
Gibby13
Same issue with my V1 gen2. Weird thing is if I open door and it turns off,then passenger opens door it will turn on. Sometimes with both doors shut it won't turn back on until I press the button on the V1.
the way they started making these since the k2 is the system wakes when the drivers door is opened I can only imagine that they have expanded on that, you may want to consider hard wiring into a different power source like the passenger airbag light.
there is possibility of it maybe being a fuse option? on the k2's there is a fuse to move position in the inside dash fuse panel to provide constant power to the accessory socket so it remains powered when the vehicle is shut off.
Gibby13
I initially wired into the overhead fuse for home link. Don't do that lol, crap went wonky. I have the power magic for Blackvue wired in currently on the same fuse as the V1 but it doesn't have issues. I'll check in the morning which one I am currently using. I went through the wiring diagram a few times and could not identify the fuse you used to be able to swap for retained power.
Jared Drexler
TIA
Same issue with my 2021 caddy ct5. dealership says its designed that way.
Gibby13
So I played around with this today. I was using F26(USB/SEO RAP) and F14(RT DR PNL) with the Power Magic. The V1 and the dashcam get power from the Power Magic. I switched to using just F14 and no issues so far.
justdanorm
TIA
Did you ever get a resolution to this? I've had it at the dealership multiple times now and they can't figure it out either.
JoshC84
Did anyone find a way around this. It's really annoying having everything plugged in reset every time I close the driver's door.
EMTPete
Northern Virginia
I am also having this issue with my 2021 Yukon Denali. My dashcsm doesn’t like this at all. I’ll probably just end up getting a hardwire kit for it.
MLou
Has anyone found the solution yet? Just bought my 2021 Yukon. I don’t recall it cutting off when opening driver side while running but did notice once it returned from dealership after an inspection. It is driving me insane. Both front & back driver side doors cause a reset on radar while vehicle is running but not passenger. That seems like a flaw …. Not a safety feature.
JeremyLaurenson
I have the same issue… question for you all- this seems to affect lighter socket as well as usb and the aforementioned fuse location…
Are you using a fuse tap or lighter port?
I am thinking of building a tiny UPS to bridge the second or two of power outage…
JeremyLaurenson
Someone over at maker.pro suggested using a super capacitor (this) in order to bridge the time gap if youre hardwired. I have it installed and it works like a charm on a WolfBox 900 so I can open doors all day long. It actually will keep it running after the power is shut off for a few minutes, as its sized for a few seconds at 2A and the cameras do not draw nearly that.
I need to do some more testing to make sure there isnt something else going on in terms of the actual hardwire power kit I have since it uses an always on as well as an ACC tap, and I have this on the ACC tap. Jury is out on whether the actual power draw in my situation is via ACC or hardware primarily with ACC just a sort of indicator.
Either way, this stop the cutting out.
JeremyLaurenson
I can confirm that my rear view camera works for an additional 7 seconds with this super capacitor... as there only power source... and the cutout is about 2s, so this absolutely works for me.
Durobans
