Tahoe_SSV
Can anyone tell me if there is a tow hook to shackle conversion for the Tahoes? I see them for 07-13 1500s. Are Tahoe a d Silverado tow hook set up the same?
you would have to have something made, you could take a regular tow ring off and take it to a welder or machine shop and tell them what you need, take a shackle with you so they can take measurements and be sure it sticks out far enough to even get a shackle on.Can anyone tell me if there is a tow hook to shackle conversion for the Tahoes? I see them for 07-13 1500s. Are Tahoe a d Silverado tow hook set up the same?
and why is this in the electronics forum?![]()
I just like the way D rings look hanging off front of truck..IDKWhat's the advantage of shackles over tow ring? I searched but only found comparisons between tow hooks and shackles..
in that case 1 strap and 1 shackle is all it takesI agree, they look cool!
I think I see a reason, recovery straps. You can unbolt shackle and put strap eye through there and bolt it back on..
If you had both vehicles with the tow rings.. You can only loop one end with a strap..
Now you made me want some shackles!
I didn't realize this section was electronic section. I thought was exteriorWhat's the advantage of shackles over tow ring? I searched but only found comparisons between tow hooks and shackles..
