09 Bose Speaker question
jz0717
Looking for a fix. Just picked up an 09 Tahoe Hybrid with Bose/Nav. I think the driver rear door speaker is blown. Should I just replace the Bose speaker (part number?) or should I swap out all the speakers for some other 2 ohm speakers (Infinity Reference)?
shundal
NorCal
If its just the one speaker, they are pretty cheap. It's part # 15186669. They are between $30-35.
Modded
That Guy
Swap both the rear ones out with aftermarket ones (like the Inifinity ones you posted). The single stock one is not worth the $40.
It will run you maybe $50 at most for the pair of speakers alone. Don't buy any speakers past 60w RMS because the stock Bose amp does not put out enough power to make anything that needs more than 60 RMS sound good.
J
jz0717
So the bose speakers are of different ohms? The fronts are 2? The rear doors are 4? How about the D Pillars?
Buford bubba
