RedRocker
Back in Black
I installed a pair of BT adjustable front struts and the BT 5305 springs in the rear with a 1 inch spacer. I have measured time and time again throughout this process, even before the install, and every time noticed the front passenger side is 1/4 inch higher than the front drivers side. Perhaps this is due to wear on a 80k mile vehicle. Since I'm not going for the absolutes lowest drop this kit can offer, I decided to place a 10mm ring on the driver's side and a 8mm ring on the passenger - this brought the difference down to just under 1/8 inch now. My question is if I wanted the FR and the FL to be dead on level, couldn't I simply add a small shim between the strut mount and the lower arm on the drivers side? I think it would be a simple and straightforward fix. Opinions anyone?
