07 suburban.
lee.solorzano
I have white smoke coming out exhaust and slight shake in motor. Any possible idea. And dose any one now what 5z3 I can replace my motor with it aluminum block vin 3
GMT800 2005 Tahoe Z71
Navy Supporting Member
What @PNWTahoe said. Needs a compression test with all plugs removed and inspect the plugs and post pics here of the plugs. Likely, if it is head gaskets, the coolant is in the oil and the oil will look milky and will also show on the dipstick and under the oil fill cap. Is oil fuller than normal and coolant low?
lee.solorzano
lee.solorzano
I was thing head gasket. Just got the truck 2 days ago. Was taking to shop cause they said Tran might slip. Drive 15 min then I saw all the smoke every where.
lee.solorzano
lee.solorzano
I’m hoping not motor. It code 3 aluminum block hard to find
lee.solorzano
lee.solorzano
Just called the pulled in shop now to. Check it.
lee.solorzano
lee.solorzano
Any one know if I can put a 6.0 in it if motor bad. And how hard would it be
lee.solorzano
lee.solorzano
My truck I left at the shop 8 this morning now they pulled it in to check engine
lee.solorzano
lee.solorzano
Well it turned the cylinder head and lifters on the right aide were bad 4 lifters stuck So I sent to replace the whole engine.
sorry about your luck
lee.solorzano
lee.solorzano
It ok. Getting a new engine so should have a lot a great miles out of the truck
Lee, you have an LC9 engine. You can easily swap in another 2007-2009 LC9 or LMG or a later year (2010-2014) engine with the wiring for VVT. It is not a lot of work to swap in any L9H, L76, L92, L94, LY6, L96 engine either. However, all of these engines were made to work with the 6-speed transmission in your truck and will tear up your transmission unless it's built to take the power.
You could also use the block and heads from an LY5, LH6, LH8 and use your LC9s intake and fuel system to retain the FlexFuel capability.
The LC9 is a great engine.
lee.solorzano
lee.solorzano
Thanks for great info I will show my mechanic this info great to know all that
JeffK
