06 GMC Yukon 4 12s ported with 4k+ RMS or 6 12s ported with 7k+RMS
skyhighsami
From the 2nd row buckets back I know 4 12s in a ported box will fit with no issues. The sub manufacturer suggested about 1.3-1.5 cubic feet per sub ported. So with 4 I would be looking at around a 6 cube box and with 6 about a 9 cube box. If I wanted to keep the box under the window line, make the box go fit from side panel to side panel as tight as possible (not just wedged between the wheelwells and then have the unused space between the wheelwells and side panel) about how much space would there be between the box and door on a box in the 6 and 9 cube range? Thank you
I guess that you are into setting off car alarms and letting your neighbors know you are coming when you are 2 blocks away. Have fun.
Hodmjstone
