01 yukon denali bose premium
sukitslowly
i want to use the factory wiring for my aftermarket 4 channel amp i just don't know where to find the plug
S
sukitslowly
aftermarket stereo aftermarket speakers and amplifier just wanting to use the factory wiring
Call Crutchfield and explain what you are trying to accomplish, and they will spec and sell an adapter to you that will allow for a plug and play installation with no cutting or soldering, as well as preserve your steering wheel controls.
you just need a module then that connects the head unit and then you run your RCA's to the amp from the head unit and then amp output wires back up to the harness
there are a few diffrent brands out there pac, metra, etc
a pro tip
run your amp power wires down the left side and run your rca's and speaker wire down the right side, this prevents HUM-ground interference.
and use "shielded" RCA's they cost a little more but will be crucial to help prevent hum
otherwise...... you can end up doing it twice
a coat hanger wire works great for feeding the wires under the carpet
KMeloney
Your best bet is to put this in the '01 model section.
agmanw8n
