01 Hoe w/ 20s & 37s
BrettsdirtyHOE
Couple of updates for you guys! Recently I installed the Zone 1.5" body lift, new bilstein 5100s, and a couple of other little things!
Didn't know zone made a 1.5 bl for the nbs tahoe. What kit did you use the silverado kit.
Sickblutahoe
Montrose CO
Bruce & McAllicaster quick question i have the same 6 inch fabtec lift but in 4wd im gonna do the ford keys and spacers did you guys have to lengthen anything or will i be ok with the suspension set up i have??
McAllister513
McAllister513
No you don't have to lengthen anything! Just put the keys in and crank it to wear you want it!
The only problem that I had with my Fabtech lift is that the shocks that came with the lift were to short after I cranked up the t-bars so I went with some Bilsteins but other than that I haven't had any problems!
brucebruce45
I had a pro comp which is a full drop. Means u can crank more with better angles
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Truck looks great. Can we get a rear pic though. I wanna get the 1.5 but im curious to see what the gap is like in the rear
McAllister513
McAllister513
Between the wheel wells?
If you have the factory cover in the rear wheel wells it covers the gap perfect but I don't have them so you can see through on mine!
Bad in Black
Zone 1.5 Body Lift Question
How do you raise the rear bumper? I hear that the rear bumper is different than the Silverado.:think:
ZaZaZazzels
