01 Cabin Air Filter Swap
cnatalie
St. Louis, Missouri
01 Cabin Filter Install
Alright, this is the 1st time I remembered to take pics as I did something to my truck. I found that this replacement is super easy. $16 at AutoZone and a ratchet. 1) remove the 3 screws holding the cover under the dash (above the pass. feet). 2) remove the screw holding on the cover to the cabin air filter. 3) replace the dirty filter with a clean filter. 4) put it back together. Very easy!
There are a couple of different filters you can get (carbon filter, paper filter, etc.) I went with the paper because it was cheaper but wondered if I would have smelled as many skunks on my last trip to Arkansas if I would have gone with the carbon. Dunno.
Anywho, here's the pics.
BOSS
The People's A D M I N
Dallas
Great post bro, thanks for that. I have an 02 and replaced mine and the only issue I had was that I couldn't figure out which direction the air flows? Do you know?
B
BOSS
Dallas
...huh? what and where is the cabin filter in the NBS style?
good post cnatalie :)
I think they stopped putting them in on the 03 and up models? Can someone confirm that please
BOSS
cnatalie
cnatalie
St. Louis, Missouri
B
Yeah, didn't even think about that when I was doing it because I didn't notice a difference on the filter. Eventhough everything seems to be working fine, I might wanna check that out tomorrow.
---------- Post added at 12:45 AM ---------- Previous post was Yesterday at 11:29 PM ----------
damnit! :( why did they decide we dont need filters to help with our health anymore? lol....
I read somewhere that they stopped them because people were complaining they didn't know they even had them, but I think we can agree it was because they could save a few bucks leaving them out.
rob71
Crystal Lake, IL
I would go with the carbon filter if it's not too much more $$$. I have an E-class Mercedes which has pollen filters and a separate carbon filter - you push a button and the carbon filter is switched in. The worst smells magically disappear.
Max
Mile High
Denver
I have the carbon ones from the dealer and they're great, made a huge difference when driving through foul-smelling areas.
Effeckt
Resident Cards Fan
Phoenix, AZ
Thanks for this post! I have been needing to do this soon and now it will take less time for me to figure out where it is.
02TahoeMD
somewhere on the road
A little trick I learned for changing mine without loosening (or losing for that matter) that accursed screw up against the firewall - If you look at the filter trim piece, follow it backwards from the screw (as in picture 1 on the first post ) and up to just under the hinge point in the dash. You will see that the trim piece is held in with a simple tab / slot point. Work a thin flat head screwdriver gently into the tab and you can pop it out of the retaining slot. Dont try to force it or things are gonna crack, but it can be worked out slowly. This will allow the trim piece to droop, you can then pivot it on the screw and pull out the filters. Put in your new ones and then just snap the piece back in place.
bthomas02tahoe
New Castle, DE.
Wow that thing was really dirty! Makes me wnat to run out and buy a replacement right now! I think this will be next weekends project for sure!
cam3439
I have an '02 and mine was dirty as heck at 100k. I have changed mine out a few times since then. If it's your first time changing it out and it's never been done (or it's been a good while), you should put a plastic bag underneath the work area to keep all the debris from falling onto the carpet. I had leaves, a lot of dirt, and even moths in mine.
I thought that this helped keep the evaporator clean. I remember having to clean out our old suburban's evaporator because it got so dirty with dirt that it turned into mud and clogged it all up. It wouldn't cool as well. Glad that mine has the cabin air filter to keep this from happening.
cam3439
Does anyone know the year they discontinued the cabin air filter? Was this only in trucks/SUV's or for all GM vehicles?
MonteJ
