Best Brake upgrades
livingez_123
Sandy, OR
Hello everyone, it's been a long time!
What is the best bang for the buck, for brake upgrades for my 08 Denali? Would prefer it to be a direct bolt it, but if things need to be modified, that's fine too. I'm going to need to do complete front brakes from calipers to rotors soon so I might as well go bigger if it's reasonable.
Marky Dissod
What is the best bang for the buck, for ALL THREE OF MY DENALIS?
Would prefer it to be a direct bolt in, but if things need to be modified, that's fine too.
(Well, for the '05 & '01, just ask for *2010* Yukon Denali front brake *caliper brackets, *calipers, *rotors, and *pads, '05 or '02 brake lines will connect just fine.)
(2010 Yukon Denali front brake calipers and pads are likely not enough of an update/upgrade for your '08 ...)
For your '08 Denali, just ask for 2020 Yukon Denali front brake *caliper brackets, *calipers, *rotors, and *pads.
NOTE:
You'll also need washers, don't yet have a definitive answer about what kind of washers ...
NOTE:
Don't yet have the ability to speak on which brake lines to use.
NOTE:
Also, the inside of your wheels may interfere with the caliper bodies. If you insist on keeping those wheels, you can grind down the calipers' faces quite a bit ...
The Baer Big Claw rotors and adapters are probably the most reasonable upgrade. (for aftermarket)
the kit provides larger thicker rotors and a bracket that allows you to keep the stock caliper and use whatever normal pads you like
I have had them for years (front & back) and the rotors have never worn out I have had them turned 3 times already and they still have a ton of life left
front & back will will run you about $1500. Others have upgraded to the 4 piston stock calipers found on the T1's
Foggy
KS
I really like my powerstop truck & tow rotors/pads kit.
They are stock size so no mods necessary. They bite really well and last
a long time. Slotted & drilled rotors with tow pads...
I could really tell a huge difference from stock for sure
davesproblem
