Aftermarket Magnaride Bouncing
Yes. Parts Geek. TRQ brand. I’m not sure what a sitting still OEM bounce feels like, but this in-motion bounce is abnormal to me. I recall the Cadillac ride I had when I purchased the truck. This is faaar from it. Should there be a “Settle in” time for these struts?
the TRQ brand is a 1A auto part, (they own TRQ) my personal experience with there parts is less than stellar.....
the only thing that would "settle or break in" is the strut spring height if you purchased a complete new strut rather than just the shock.
when new it may lift the truck and inch or so but would settle after a few weeks
S
Scheme1
Yesss, per their written instructions, give it time to let the coil-over settle. I’ve order from them in the past without incident. Josep Garcia makes a good observation. Z55 & Z95. When placing my order, I provided my VIN and I believe a part number. Chevy informed me the part numbers have change from a few years ago when I looked into getting new shocks & struts. I guess I need to ascertain what I actually have; Z55 or Z95 since they both have the MagnaRide system.
z95 was the on the escalades, still doesn't explain it working and then NOT working
S
Scheme1
True! Let me say, I’ve gone years needing these struts & shocks to where they were shot. I’m rocking side to side or up & down over bumps. There were times I’d take it for service, they’d raise it to perform service and when I got in to go home there was such a nice ride compared to rocking & swaying I was used to. Struts/shock expanding… That softness over bumps is what I got after installing them (fronts). Not still bounce. The rear seem fine, I guess cause those are actual air…. lol. That’s what I mean about working and not. It could’ve been they hadn’t settle down?
no telling...., if the DIC is out you won't know if there are error messages at this point, need a scanner
mrkev
I have a similar experience when I installed aftermarket Arnott magneride. It rode great at first, but after 1000 miles, it seems to have gotten more bouncy. I do realize the feeling "bouncy" is subjective and I think partially, I have gotten used to the ride and now am noticing every single bump. I will soon swap the stock springs into my arnotts to see if it's less bouncy. The arnott springs have added 1.5 inches lift up front.
Also many aftermarket companies that offer magneride offer active and passive versions. passive is a bypass version that disables magneride.
petethepug
Michael
SoCal
With all the facts, an Internet diagnosis is ez.
Only one brand shows applicable for 07 Tahoe with z55/autoride …
All the other options show for the rear, without z55, exc. z55 with RPO Code Z95 (MagneRide Suspension) or excluding z55.
The only option for TRQ shows as …
A Conversion kit made of subpar hydraulic shocks with resistors…
Or .., the actual AC Delco z55 replacements guaranteed for life.
All the other options are not applicable or incorrect. The TRQ conversion kit is already known to be inferior.
The subpar options currently available cause so many, so much grief & frustration as well as draining their wallet, it’s important to help others from duplicating the same process.
S
Scheme1
Yeah, it’s out. Gonna send that out for repair. I plan to purchase an inexpensive bi-directional scanner where I can ascertain what’s going on rather than paying a shop a diagnostic fee PLUS… I did stop in a Chevy service shop where the system was scans the vehicle when it comes in the service door. They saw nothing wrong. That was probably a preliminary scan of the system? Idk. All this computer crap! One can dislike or like it. I’m scheduled for service so they can look into my issue. They’ll probably tell me I need to buy OEM. I think I may be on to something, given conversations here.
A while back I was informed my Tahoe has the Z55 suspension. Another conversation I was informed I had the Magnaride struts, so I was always looking for the Magnaride struts which is why I purchased them.
If the Z 95 & 55 utilize the same strut(s) and it’s the ECU that dictates their functionality then my problem lay with the ECU? But, I had no issue with the old struts other than old and leaking. If the same struts are used then the ECU should adjust according to its programming, yeah?
S
Scheme1
This is what i purchased
S
Scheme1
I’m learning. This bounce one could not get use to. lol.
Nando2724
