Torn cv axle boot, 3" lift, replace with OEM or extended travel axles?
bdbull
Went to do the front brakes on my 2010 Avalanche today and found the driver side cv axle boot completely torn. So I decided to wait on the brakes until I fix the axle so I don't get grease or whatever all over the new brake parts. So, my question is if I should go with OEM or extended travel cv axles for lifted vehicles. I put a 3" lift on back in 2016 and have been running the OEM cv axles since then and before. This is the first time I've had a torn boot so I'm almost thinking that the OEM axles will be fine and I don't even need the extended travel axles. Any opinions? If it ain't broke, don't fix it?
Dustin Jackson
3 inches of lift does put them at a bad angle.
You could try new axles and see how long they last.
Longer axles or a diff drop might be the right way to proceed
CRN_25
