iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,036
- Reaction score
- 531
Back left wheel rotor back plate I believe. They said it was flattened (the rock)where was the rock?
Correct, it reeked after the shop gave it back. I’m still driving the loaner I got from a Friend till I figure out what route I wanna take for my shocks.Slight seepage and especially since that is the worst, it is not critical. I would be more worried about the rust.
If rust is that bad, could have a fuel leak up on the top of fuel tank. But, you are saying that never smelled fuel before the shop looked at the truck?
A bad u-joint won't necessarily have slop in it. It has to be removed from the pinion and manually moved by hand to inspect. Or you can jack up the rear axle, put the truck in neutral, and rotate the shaft by hand to see you hear any creaking noises or feel hard turning spots. You could also put the truck in gear with the rear wheels off the ground and let it idle. With the rear wheels spinning, maybe you'll be able to track it down. But, jack up the axle by the pumpkin so as to keep same geometry as going down the road.Any way I can narrow it down and know for sure? I checked my u joint but it feels solid. Doesn’t turn and doesn’t have any slop in it. Not much knowledge on park brake.
