Need help!!
Adrian1998
Need some help!! Does 2dr tahoe leaf springs fit 4dr tahoe?
Welcome to the Forum from NH.
Can you provide the specific details of your truck? Year, and last 8 digits of your VIN.
Multnomah Falls
Welcome to the forum from Oregon. Post pics of your rig please.
While the measurement on the rear leaf springs look to be the same, measuring from center pin to the eye on each end looks to be 27" on front of spring and rear of spring, the width can vary as well as the leaf pack count itself. May require a different axle pad for the springs to fit and mount properly. The thickness of the leaf spring can also be different. There are samples of them at RA. I am saying all this assuming you have a 1998 Tahoe.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
rick3645
