Leveled and now brakes seem off. Calipers or??
ArmedArtist
San Diego
So I finally installed my Ford Keys, Z71 coils, spacers, sway bar extenders and Bilstein 5100's. The Tahoe looks amazing now. But now that its "lifted" when I hit the brakes kinda hard, the front driver wheel seems to grab a bit more than the other side and the wheel pulls some. All the other parts on the truck looked ok. One balljoint needs replacing because of a torn boot but other than that it seems to be ok.
So think I should clean/rebuild the calipers and see if that helps? Anyone else have some front end issues after leveling?
A
ArmedArtist
San Diego
Had it done. Did the level stuff. Drive it to get new tires mounted. Then went to alignment shop.
osiris94ej
Casper Wyoming
Try and compress the pistons in calipers, check the caliper slides, other than that it's hard to say without it being in front of me.
Sent from my SM-N920V using Tapatalk
A
ArmedArtist
San Diego
It feels to me that the diver side is grabbing more then the pass side. And thats whats making it want to pull. Maybe its always done it and I just now feel it with the new Keys and a good alignment again?
osiris94ej
Casper Wyoming
If the rh front caliper has pistons that are seized it can't extend the piston effectively to produce proper clamping force on the rotor.
A
ArmedArtist
San Diego
I think from the posts so far that I am feeling the jounce gap. Should I fix that? And also now that the jounce gap is pronounced I can feel what the brakes have probably been doing for a while. Ill look into the caliper upgrade. Will I need the new booster also?
01Konvict
Boats n Hoes
Raleigh/SML
Order 07-13 front brakes and there 1" bigger so need new rotors and pads. Hydro boost is a plus but not required. Stainless steel lines helps also. Then set jounce spacers and get normal drive with hella brakes
whitey hoe
I agree w 01 konvict on the jounce stops and the hard nose dive
whitey hoe
Please explain these ideas of yours to me konvict ,I'm new to the brake upgrades and am getting ready to do my 05 Tahoe,I've already done the stainless lines,thinking drilled and slotted
01Konvict
Boats n Hoes
Raleigh/SML
Basically buy the newer 07-13 Tahoe or Yukon front brake calipers as they bolt right up to the knuckle for 4wd or spindle for 2wd. Then get front rotor and pads for the same years caliper. I ended up going with power slot rotors and hawk light truck pads. I found them on tire rack. I chose them for the higher friction rating and both were made for each year caliper. Put some new parking shoes while you got the rear off.
Then if you need more pedal pressure then swap to hydro boost. That made a huge difference in stopping power. Also my T fitting with barbs sucked from the local lowes so I ordered a 4 rib large barb from Amazon. Sealed much better.
http://www.tahoeyukonforum.com/threads/hydroboost-conversion-diy.35078/
Durobans
