Just an LT
Sport99
CT
Hello TYF!
I've been a long time lurker. I joined way back when I had a 99 2 door Tahoe sport (hence the screen name). Since then I've bounced around from an 02 Yukon XL, to a 95 Turbo Diesel 2 door, to an 04 Suburban Z71, and now I've settled into this 07 Tahoe LT. What originally started out as a search for an LTZ ultimately landed me on a truck that was equipped just the way I DIDN'T want it (Wrong trim level, wrong color). This 07 is a solid runner and it looked like it was waiting for someone to love it, so I accepted the challenge.
When I purchased the truck, it had a nasty vibration at highway speeds. 2 u joints later and problem solved. I then went on to install new pads and rotors front and rear. An air filter & oil change later and it was ready to call my own. I've also purchased spark plugs & oem wires. (I like to tune up as much as I can for piece of mind).
I started this thread to document the light build I've started. The pictures below show some of the mods I've done. I've learned a ton by lurking here, and wanted to share my progress. There is still more to come, as I am always impressed by the things I learn on this forum.
On to the pics!
When I first picked it up - unloved Silver Birch LT-2 - (if you look closely you can see the ugly pin stripe right above the faded body side moulding)
Interior - (before)
S
Sport99
CT
First things first - Removed the pin strip and tinted the front windows. Now that body side moulding looks even worse!
S
Sport99
CT
Scored some OEM Brushed Metallic dash trim from a Sierra. I still need the front window switch trim as its different than the Tahoe, but hopefully I can find a set out of a Z71 Tahoe/Burban to make my power folding swap easier.
Before:
During:
After:
S
Sport99
CT
I've had it with the faded body side moldings. I couldn't decide if I wanted another set of painted moldings with our without the chrome strip. I searched countless pictures, and came across a member who had Escalade moldings put on his black LTZ Tahoe. The pic was small, but I liked it enough to source a complete set of brand new Escalade moldings. They weren't cheap, but they were worth it in my opinion.
crap faded moldings:
A little bit of masking tape, heat, patience & solvents:
Finally a difference! I used plastic razors to remove the glue left on the doors. I soaked a rag with brake parts cleaner and carefully saturated the remaining glue in it, which made it a lot easier to remove.
S
Sport99
CT
Once I put on the Esky moldings I knew I needed to compliment them with a few more chrome pieces. I found the OEM GM chrome door handles and decided to install them. I decided to wet sand and buff my headlights and give the truck a bath. Its finally starting to look less LT-ish
S
Sport99
CT
In my quest to rid the truck of the LT-ish look I knew I had to do something with those ugly roof rails. I was lucky enough to come across a for sale thread posted by JuniorSS. A ride out to long Island was well worth it to pick up some LT repellent.
I sent the Escalade spoiler and rack caps out to get painted. The irony is that I really wanted a white truck, and now I had white parts. I sent them out to get painted, and they arrived back coated in Silver Birch. I couldn't wait to install them. I'm glad to report, the install was simple due to the info I found on this forum.
This:
Leads to this:
S
Sport99
CT
Current state of affairs:
Silver Birch LT-2 (leather, sunroof & bose)
Added the following:
Escalade chrome door modlings
Escalade rear spoiler
Escalade roof rack
Future aspirations:
Lighting - as of right now my lighting game is weak HID's and LEDs front and rear are a must
Power folding mirrors. (I swapped them into my 02 yukon, and I've found its even easier on an 07)
SLP resonator delete
Tow hitch cover
nav / backup camera.
LTZ front grill
Heated seats and steering wheel
Two pics showing my current progress:
Fosscore
Looking good man. Like the change out on the front dash trim. Looks nice.
Mine started as an LS. Just takes a little to get there.
08HoeCD
Nothing at all wrong with an LT, and your ride is looking good. ;)
93blkongreenpro
Looks good so far!
What are you doing with the radio bezel trim?
Sent from my SM-N910P using Tapatalk
S
Sport99
CT
Thank you!
Are you referring to my old wood bezel trim?
93blkongreenpro
Thank you!
Yes. All of it actually. Want to sell it? I cant find the right wood grain radio bezel for my yukon. But ill take all if it if you are not using them.
moto
