Resistors for LED front turn signals
AZSCTACO
Phoenix, AZ
So I put some resistors on my new LED front blinkers to avoid hyper flashing....my question is do I need to mount it to metal, or can I just let them hang behind the headlight? I know they put off some heat but mounting it in such a limited space is a pain. Thoughts?
mrcajunjoker
baton rouge, la
I didn't mount mine. There is a 10mm bolt just below the headlight that my ground is wired to but the resistor just sits in there and works just fine...
AZSCTACO
AZSCTACO
Phoenix, AZ
Cool....thanks for the replies. I left mine unmounted and so far so good....no issues.
Graystone_OG
NYC
This was my solution. Used outdoor double-sided tape and a piece of cork board and mounted it on that. No problems at all and out the way of other cables. I did the dual DRL/Turn signal mod.
JT 07LTZ
Western, NC
Do you have a wiring diagram or could you tell me which wires you hooked up to the resistors? I am about to install switchbacks and can't figure out which ones.
Drewphil
