Burb!!
Biloxi, MS
Installed in channel window visors.
Sent from my LG-H900 using Tapatalk
aflumb
Las Vegas
Got it ready for the wife. Deploying again and didn't want her to have any issues. So with that said:
Changed the oil
Cleaned the air filter
Greased the front end
Fix air leak on helper bags and moved the valve to add air
Then I rotated the tires only to find out that after 39K miles they where separating. So $360 later 4 new tire mounted and balanced. Tom I will detail inside and out
AppocAlexx
Darth Appocalexx
Abilene TX
That sound about right, before all deployments something will go wrong. When you gone nothing happens, get back and hell breaks loose.
redeknightjr
Maybe its good?.....Helps keep ya focused and mind off other things brother!
1SG Retired
Changed the oil
Thank you for your service :patriot:
Fosscore
Changed the oil
Always something to sort out for the ladies. Haha
Thx and keep safe wherever u are heading to.
aflumb
Las Vegas
Well i have been lucky. this is the 7th one, and it has been the only one where i had stuff really happen before i leave. the biggest issue is i only have about 6 days from the time i was told till the time i leave
thanks
yep gotta keep her happy
AppocAlexx
Darth Appocalexx
Abilene TX
Debadgededed today, its crazy how such little things can make a big difference. Also while doing that found that my Hoe needs a good buffin, soon very soon ill be waxin dat ***
Mrhug3
Midsouth?
Got it towed.... Had to take my dad and uncle to the airport. On the way to pick up my uncle, noticed some smoking sitting at a light. Used my aunts car to take them the hour and fifteen min ride to the airport, drop them off in time, get an hour down the road, receive phone call, missed flight, back another hour to pick them up. Caliper seized up. So now, new calipers and hoses for the front. On a good note, my sway bars just so happen to be here here too. So I'll at least have something good for today.
Drewphil
