2005 GMC Yukon Denali 6.0L V8
Things I've done to it ever sense I got it, everything is in order from the day I got it:
1. All LED interior Lighting, LED Curtesy(under the side mirror),LED license Plate bulb. Black Smoke LED Brake light + Third Brake Light, LED Reverse light Bulb, LED DRL Bulb, LED Halo Fog lamp, and the most important thing on the front, I installed a custom bracket mounted to my tow hook bolts to hold the 6000k LED LIGHT BAR! (Blue light switch mounted ontop of traction control button and AUX).
2. 9005 6000k low beam HID.
3. K&N Cold Air Intake.
4. Aux Chord into Stock GM Radio.
5 2008 Steel Silverado Rims(painted black and GMC Logo) on brand new Michelin 265/70/17 LT2 with all new TPMS Sensors.
6. Installed a Switch to turn off Air Shock Compressor when I carry heavy loads so the compressor doesn't run constantly.
7. Installed a 2004 Tahoe Z71 Roof Rack found at a salvage yard in MD(fitment was perfect)
8. Regular Maintenance, Engine Oil Change, both front and rear Differential Gear oil Change, Brakes....Tuneups.... Etc.
