Stuffed 35 12.5's with only 2.5/1 spacer lift
Mighty Hd
Florida
How about some pics where you trimmed? I bet that thing is a slug off the line with the factor gearing though........ :-(
Z1500
Z1500
I'm lucky enough to have the factory 4.10's so it's not bad at all. Lost a little spunk for sure but going to turbo it anyway.
I got the Spohn adjustable rear control arms that I'll put on in the next week or two. Assuming I can space the rear axle back 0.5-1.0" then trimming plastic to the rear seems easy enough.
Now what's going through my mind a lot is how I could space the front 'axle' so to speak, forward an inch. If someone made upper and lower A-arms that just had the ball joints forward an inch, it would be amazing.
Zed 71
Pacific NW
For the front have to tried to adjust the camber to the + side?
AppocAlexx
Darth Appocalexx
Abilene TX
@Z1500 I feel bad bringing up all these old posts but I have to ask what your measurements are at the fenders. I'm looking at doing almost the exact set up but I'm thinking I may have a tad bit more clearance up front that you with my set up.
Z1500
Z1500
No problem. Where exactly would you like me to measure from and to?
LiftedTahoeLtz
This is my 07 Tahoe ltz has a 3 1/2 lift on it I’ve been looking to put 35s on it. How much trimming did you have to do?
CKendrick
