Fosscore's 2006 Tahoe Build Thread
Fosscore
Fosscore
wow...cant believe thats the same truck..well done !
Thx man. Sometimes I can't believe it either when I look at throwback stock pictures. That's why this thread is good. Gives me a chance to do write ups with lots of pictures and catalog the build for future reference.
Fosscore
Fosscore
Noticed my 3rd brake light had a light out the other night. Hit up Amazon Prime and a new one was on my door step on Sunday for $40.
http://www.amazon.com/Dorman-Solutions-923-203-Chevrolet-Mounted/dp/B000TYQB14
This Dorman replacement unit comes with an extra pigtail that was not needed as the OEM wire and plug was in perfect condition. Fitment into the rubber boot, the 2 screw holes, the plug and above the rear window applique' is perfect. The brightness of the LEDs is much brighter than the OEM unit. The pictures speak for themselves. The unit is made in India, so hopefully it lasts as long as the OEM unit.
Dorman and OEM with included pigtail.
OEM daytime.
Dorman daytime.
OEM nighttime.
Dorman nighttime.
Fosscore
Fosscore
This week, I tracked down all the old service records from the 2 local Chevrolet dealerships in town that my previous employer (whom I bought the truck from in Feb 2013 after driving it for work since Nov 2009) had service performed at since January 2006. I found out a lot of additional info and work done to the truck that I never knew had been done. Quite interesting. I've been compiling a master file of all service records and modifications receipts with monies spent to date on the truck. I'm still working on organizing the invoices in chronological order and adding up the totals. It will be a good file to have on hand should the time arise to sell it or pass it along to my son. I have the original bill of sale and window sticker as well. Cost out the door in January 2006 was around $32K for a Tahoe LS 2WD 4.8L with upgraded leather and 16 inch wheels.
I made a run to the junkyard today just to see if there was anything worth picking off the wrecks since it was a beautiful day. Found an NBS Escalade and Suburban with a few small parts to pull off.
1. Escalade windshield end cowl covers to get the passenger side one since it does not have an antenna hole cut out. I tucked the antenna into the engine bay a long time ago. Direct swap and in great condition. Gave it a quick wash and popped it into place. Now I have two complete sets.
2. Escalade spare tire rear bumper lock cylinder cover door since mine was the textured black plastic version and the Escalade one is smooth.
I gave it a quick sand already and will be color matching it. I forgot to do this with the other parts I sent to the painters.
3. Escalade rear a/c heater climate temperature control face plate from the overhead console. I broke off two tabs from my Tahoe OEM unit when I removed the console to paint it when I redid the headliner and it has never fit correctly since then. Direct swap and only a slight difference in the graphics on the face plate.
4. Escalade roof rack center mounting posts x 2. Someone snatched the roof rack, but forgot the posts, figured they might be worth having or helping out some TYF member some day.
5. Suburban rear subwoofer box that goes under the rear driver window in the jack space. It is a touch bigger and slightly different configuration than the Tahoe version, but I have some ideas to see if I can get it to fit in that void behind the panel. Be fun to mess around with it anyways as it is in perfect condition.
I was out the door for $25. Not bad for some spare parts and a few extra screws and clips in hand.
Tahoe OEM end cowl piece with antenna hole.
Escalade OEM end cowl piece without antenna hole.
Escalade spare tire rear bumper lock cylinder cover door, rear a/c heater climate temperature control face plate and Suburban rear subwoofer box.
Tahoe OEM vs Escalade OEM rear a/c heater climate temperature control face plate.
ecordell
CordellDesigns.com
Merica
Did I read correctly that you have another escalade cowl cover for the antenna?
Fosscore
Fosscore
After picking up some spare parts at the junk yard earlier in the week, I was able to put them on the truck this weekend.
I color matched the spare tire rear bumper lock cylinder cover door and I took off the license plate lights and color matched them as well.
I sprayed off the hood heat shield with some fresh water to rinse it out and then gave it a good coat of black spray paint and put it back in place after it had completely dried out in the sun.
I replaced my Tahoe OEM rear a/c heater climate temperature control face plate with the Escalade one because of the 2 broken clips in the back that would not hold it properly in place in the overhead console. Now it fits tight again. Direct swap with Tahoe unit and knobs.
Looking around the engine bay for something else to clean, I decided to paint my alternator. I pulled out a couple of small artist brushes and went to town with some Rustoleum Flat Black paint. I think it looks pretty good for having done it in place and gets rid of that horrible oxidized look. There's nothing flashy in my engine compartment so I decided not to use gloss black, but think the flat black blends nicely with the rest of the compartment.
I pulled off my CAI and sprayed the chrome end cap with some gloss black spray paint as it had a bit of rust on the end that I could not polish out. I think it looks much better now in black vs. the chrome end cap that it came with. Again nothing too flashy in my engine compartment and blends in better than just the one piece of chrome.
Fosscore
Fosscore
@ecordell
No sorry for the confusion. I had my Tahoe OEM cowl end covers and I picked up a left and right Escalade set. I put the Escalade right side one without the antenna hole on my Tahoe, which left me with a 2nd spare set. The Escalade left and Tahoe right with the antenna hole.
I color matched the spare tire rear bumper lock cylinder cover door and I too off the license plate lights and color matched them as well.
View attachment 59418 View attachment 59419 View attachment 59420 View attachment 59421 View attachment 59424
nice attention to detail :)
Fosscore
Fosscore
Maybe...I just think he is running out of things to mod since it is pretty much complete LOL...I kid...I kid....
:roflbow::roflsquared::nono: Oh man...so says the money spending coercer ....bawahahaha...so much money magically left my bank account ahem looking back over old posts. :lol: :Handshake:
The big projects have pretty much been completed. Now it's just the little stuff and keeping her maintained. The junkyard was a great stop that day and I found some cool stuff, for dirt cheap and in good condition. Always a win. Pretty cool to dig around a wrecked NBS Esky even though the vultures had pretty much picked it apart like roadkill.
OHSIXX
Milwaukee
The guilt keeps me up at night .....I'm glad some of my ideas were brought to life. The end execution is nothing but perfection. And I totally agree that sometimes the small things make the biggest statement...at least to truck guys who know what comes on certain models and what does not. You are the envy to many on this forum. Well done bud!
Fosscore
Fosscore
Still madly in love with this Tahoe...
Thx man.
Thx sir. Appreciated.
BadDaddy2003
