LS9 Supercharger on 2013 Yukon XL 5.3L or SLP supercharger
Rawlings09
I am looking to buy a supercharger for my 2013 Yukon XL 5.3L 4X4, I read that the LS9 supercharger can be put on a LS3 but I haven't seen any forums stating if there will be any necessary modifications to install it. I know that the SLP supercharger is made for GM trucks and SUV and is a direct fit which would be easiest and im not sure if it is true that it would increase my hp to 550. However Im pretty sure that the supercharger for the LS9 will have a higher output of hp than the SLP. Im just curious if it is possible to install the LS9 supercharger as easy as it would be to install the SLP supercharger? But right now im leaning more towards the SLP just because it seems to be the easiest and it is street legal.
SLP- http://www.jegs.com/i/SLP/847/92020A/10002/-1?parentProductId=
LS9- http://www.jegs.com/i/Chevrolet-Performance/809/19244103/10002/-1?parentProductId=
FrankU
Babylon New York
You have cathedral heads on the 5.3... The LS9 S/C bolts up the LS3 rectangular heads. The SLP or a Magnacharger will do you fine.
Best of luck !
Rawlings09
Rawlings09
So would all I need is the rectangular heads to get it to fit properly?
Rawlings09
Rawlings09
Im just trying to get the best hp for a reasonable price.
CrashTestDummy
Pearland, Texas
Hmm, the correct SLP system will bolt on to your existing long block, and is ~$700 less than the LS9 unit that will require you to swap your heads. Cost-wise, it seems like a no-brainer, for similar performance.
01FormulaTA
The Rectangle Port heads require a 4.00 or larger bore and will only fit 6.0 or bigger, you would need an adapter to mate the LS9 blower to cathedral heads would be the only way to run it...much cheaper to just get a kit designed for your truck
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Maggie tsv 1900 will do you just fine. Everything in kit is made for the 5.3. That's what I'm running and pushing 10psi
Ben Hinz
Winter Garden, FL
Or look into an LSA Swap. Using the SC off of a CTS-V or ZL1 seems to work pretty well. Everything can be down for under $2500-$3k
Tiki
If you find a take off at a reasonable price.
Trc54
There's a guy on facebook that sells his kit for like 1900$ which includes the blower and adapter plates and a few other things, to make the lsa blower work on a 5.3
Ben Hinz
Winter Garden, FL
Could you maybe post his name or page so I can find him??
davidl13
i put a magnuson tvs1900 on my 6.2 denali... perfect match...
63Blackseries
Canada
How do you guys like the tvs1900? How much HP and Tq did you get out of it? I want to get one bad but looks like It will cost me around 6k would it be worth it?
sumo
rhode island
Very much worth it. I'm pushing about 400 at the wheels with 10 lbs boost. I have a 3.0 pulley to install and it will give me another 1.5 maybe 2 more pounds of boost. Very pleasing when you got that one guy behind who tries you instantly pass you when merging on the highway and you're like nope
davidl13
The tvs1900 is awesome.. I love it.. not whinny and passing power even at altitude
davidl13
I have not been able to Dyno mine, I have a 6.2 Denali awd and no one around here has a 4x4 Dyno..
I installed the smallest pulley so I am about 8-10 lbs instead of 5-7..
I live at 5000' elevation..
My seat of pants Dyno says the supercharger got me back to sea level stock power..
The smaller pully took me over stock power at 5000'
cmc76
i would really like to hear from someone who put this on
Drewphil
