Da90
Tulsa, OK
Damn I like that roll pan. Which one is it? Any other pics?
I have no idea what roll pan besides it is fiberglass. When I bought my house from my cousin and it was in the garage. I got rear ended while my truck was in the body shop. So I decided to put it on.
Before third brake light...
Fosscore
Truck is looking good man.
Five
North Carolina
4 hi mod, repaired key fob, and fixed the power mirror switch. Five channel amp install coming this weekend and a virtual laundry list of mods to come since I inherited my '02 Suburban LT 4x4 from my wife.
MinnYukon
Got some work done on my 04 Yukon. Replaced leaky intake manifold gaskets, upgraded to an AEM air filter, and installed the Airaid intake tube.
shakedown067
New sub box for an 8" sub. Now I need a better woofer. Of course it still needs to be covered.
Yukon Lover
Maine
Knock sensors done already? If not definitely would have done those while you were in there.
Sent from my Z797C using Tapatalk
Matahoe
Military
Grand Rapids, Michigan
We had a bad gas smell coming from underneath for months. Fearing the worst I took it upon myself to remove the tank to inspect everything. Long story short the pump was severely corroded to the point of leaking. It was a bear to replace. It needed new connectors and such. Luckily I got a good price on an identical Bosch unit. Guessing we saved at least $500 easy. I wish I would have taken pics.
Since it was up a bit on jacks we also changed the Autotrak II fluid in the NP8 transfer case.
Rivieraracing
Bought an OEM electric fan harness from a member on here (thanks again TJD3004) to replace the LS1.com fan harness I've been running with for some years now, just need to find 2 replacement fan plugs for it (don't want to cut up the LS1 one if I don't have to) and find the time to install it!
DarkBlueHoe95
West Columbia, SC
New to the forum so this is my first time posting here so ill just post what ive done recently
6000k 35w low beams and fog lights
GoRhino brush guard with the guards removed.
24 inch single row full spot led light bar
led projector style bulb reverse lights
4hi mod
Park/Turn signal mod
led tag lights
led courtesy, door, and map lights
tinted tail lights
now that ive posted here all be back with updates and will be reading everybody else's posts
Martinjmpr
Littleton, Co
Finally getting around to making her "mine" after getting the pesky intake manifold gasket issue (which was throwing a CEL and preventing me from getting a passing emissions test I needed to register.)
Now that she's passed the E-test I went ahead and hooked up the Scangauge. This way I can monitor transmission temp as well as getting a more accurate DTE (Distance to Empty) and real-time MPG
Also installed the trailer brake controller.
Finally I installed the RAM mount for the GPS.
SlowD
^^ Its amazing how much nicer and cleaner those Escalade vents make the truck look!
It was slow at the shop today so I finished up the ipad2 install. I was going to have a friend mold the bezel inwards but I did some experimenting and decided to finish it myself with a few things found at the auto parts store, door edge guard and foam weather strip... I like it a lot!
Smoke Em All
Taylor,Texas
Yea the vents make a huge difference. I like the iPad idea looks pretty clean.
5280Racer
Peyton, Colorado
I replaced the antenna cable from out side in to half way connection.. I swear when I was GM tech this has to be the damn hardest thing I have ever done!!!!
omega123
Northwest Iowa
so far replaced and reprogrammed new key fobs, replaced drivers mirror, and detailed her inside and out. still need to fix my rear driverside brake problem.
Aaron_L
Arlington, TX
I've had an MBRP exhaust on my Suburban for about a year now, but after the addition of longtubes and losing the cats it was unbearably loud. Today I replaced the muffler in the system with a Magnaflow, part # 12579. It quieted the truck down but still has a good sound. The true test will be in the morning if I wake the kids up when I leave for work, lol.
D Rollins
