How to install E-Fans
bottomline2000
Dallas, TX
You'd be amazed how well our trucks run without any fans. The big radiators are very efficient so cooloing shouldn't be an issue either way. Its hard to get the truck up to temp if everything is in good working order.
I went back and checked my order. It was actually from amazon and I have the 53's. They are the higher 7 blade count model for the newer trucks. Hope that helps.
YukonXL04
The Riverboat
Arlington, TX
Pretty sure I have the 620653 in mine. Haven't had a single issues in 100+ Temps towing or idling while keeping the truck cold. Very happy with mine
DPGDirk
Good to know. I think I'll shoot for the 620653 and see what happens.
Both Dorman models have twin 7 blade fans. The factory models had a 5 and 7 blade combo or a 7 and 9 blade combo.
They're just spinning the 7 blade fans faster in the 620654...
DPGDirk
Almost done. This danged thing has fought me every inch of the way. Doing multiple other upgrades simultaneously though.
Gotta take the new belt back and get the larger one for these models.
Mounted the stinkin' relays to the PCM cover 4 different times! Fans were hitting them, so they had to come out and be moved. Mounted them upside down once.
Probably shouldn't be working that late...
DPGDirk
Done!
Does the AC clutch engagement trigger the fan on '03 and newer models or just through '02? Mine seem to be working fine, but don't come on with AC.
A few points. The instructions from LS1fans.com are not great. That's putting it mildly. There is a green ground wire in their harness that should be longer. It said "Driver side Rad mount" on one side and "Neg 12v ground" on the other. It was wrapped around a wire at the passenger side fan plug. Nothing in their instructions about this wire. Multiple other little details that are missing or not clear.
You'll probably break the plastic plug covers that cover the PCM plugs, as the OP did. They suck! Some complained how hard it was to push the pins into the PCM plugs. I found that to be the easy part- once I finally accessed that thing to start with! I pushed mine down in there with needle nose pliers and finished with a bent paper clip. Slipped right in.
The Dorman 620653 fans seem really nice. Very well made. Perfect fit and quiet. There is a difference in throttle response- not huge, but it's there. looking forward to better working AC next summer!
YukonXL04
The Riverboat
Arlington, TX
Yes the AC will trigger the fans to come on. I believe you still have to be up to a certain temperature though. I remember thinking mine weren't working, but it wasn't getting hot enough just idling... I had to drive it around some and then they kicked on. Its hard to tell because you cant really hear them. Mine are really quiet, you only hear them if they are on high. I dont remember having any problems with the harness, it would have been nice if they had added an extra 12" of wiring though.
Im also running their alternator overdrive pulley too.
bottomline2000
Dallas, TX
Done!
If you have an 03 or newer truck your fan will be triggered by ac pressure not the ac clutch. It all depends if you have the 2 wire setup to the pcm or not.
These big radiators are pretty efficient and it takes a while to get them up to temp to trigger the 2 fans on low from coolant temp.
I just saw a suburban come thru my neighborhood yesterday with its clutch fan blaring. I hate that sound and the drag it puts on the engine. Like driving around with a parachute. It was cold here yesterday and makes me wonder if their clutch fan was broke lol. The difference in efans and your clutch fan would be very noticeable during the summer and your ac should be ice cold! Glad those Dorman fans worked out for ya.
DPGDirk
Thanks!
The LS1 Fans instructions said the fan should kick on when the AC clutch engages. It doesn't say anything about different years. I'm thinking the models prior to '03 were triggered differently.
bottomline2000
Dallas, TX
Thanks!
Fans on 00-02 models work off the ac clutch. Typically when the ac clutch engages the passenger side fan cycles high. If you tapped the ac wire then this is how your fans will trigger. The coolant trigger is still there and seperate.
DPGDirk
I'm running the LS1 Fans harness. It doesn't have you tap into an AC wire on an '03. Just plug the 2 pins into the PCM plugs, hot wires to the battery red box, plug in 2 fans and a ground to the radiator support.
It did say that the fan should kick on when the clutch engages though, which is what had me puzzled.
03LTAT
If i just want the PCM flashed for fan control can this be done separately from a tune or do i have to do the whole package? If not whats the price for fan activation?
It can be done separate, you just need to find someone with a Tech 2 or equivalent. Not sure what they would charge you.
MCAT069
After searching I came up with conflicting part numbers for my application. Anyone with an 8.1 4l85e combo do this upgrade? If so, do you have the correct part number for the fans?
bottomline2000
Dallas, TX
Found a couple of e-fans locally, wondering if either would work for my '04 Yukon XL?
https://utica.craigslist.org/pts/d/dual-electric-fan-chevy-gmc/6436355521.html
The fans are universal for the most part. My first set was from an 05 Yukon. The set in my truck now are for a `13 escalade. The only difference is the blade count. As long as you have the larger radiator it will fit. I believe it is 34" between each tank and 38" end to end.
Scottydoggs
NJ
in my 03 gmc the when the clutch fan took its 3 rd and last crap on me i was out of warranty, so i bought 2 16 inch pro comp fans, ditched the shroud, ran a fog light set up switch a relay for each fan and used the on off switch as needed, left em on full time for the most part, made the ac work better then ever before.
if i had thought there was a pinned wire to add to the pcm to make it work i would have gone that route of course, but the fans were not on the 03 trucks, so i went about doing it old school.
truck ran a degree or two cooler too.
MCAT069
Thanks for the replies. The 1/2 ton ones are like 150 on Amazon. Flexalite wants almost 500 for the one for the 8.1L. The radiator is different than the 6.0 (bigger) so that's what gives me pause about using the 1/2 fans on mine.
Scottydoggs
NJ
those fans i installed were on a 2500 HD pick up with a 6.0 iirc they were 20 ish a fan.
of all the cars and trucks ive owned. i miss this one the most.
ScottS-Michigan
