Fosscore
Man that is crazy bright and looks really good. You've got a lot of mods that I do not have. Great...the project list grows once again....haha might have to pick your brain on install for this mod.
seven9st surfer
Milton, FL
Thanks. And hit me up whenever, it was actually really easy. Hardest part was getting the trim tape on the LED strip, and getting it attached to the hood straight. The wiring was easy.
mmeachem
Finally got around to installing my underhood lighting. I might go back and add another strip downward facing in front of the firewall, though, like ezdaar's. But this is more than enough light for right now, considering I had none before. I installed the switch on the backside of the fuse box through a separate inline fuse, and routed the wire through the stock harness where I could, and sleeved it where I couldn't. Can't believe it took me this long to install this. And yes, I know my hood liner is in rough shape...
Looks great
BillBlatt18
Latham, NY
That looks so good man! Love your truck by the way
Yuko04
"SquareBODluvr"
MN
They are the shocker 240, upgraded to a four gallon tank. Only a couple of months old, probably go 475.00 shipped, they were 625.00 shipped when I bought them. Compressor and air tank was mounted inside the cab.
@goodnblack ? ???
Jiggy-J
Fosscore
Just finished up with some late night detailing while the family was sleeping. Best time with no distractions. Gotta love them though. Hit the engine compartment with some Simple Green for the first round of cleaning and degreasing. Might hit it again at the next wash to give her a second cleaning before getting a shiny coat of protection. Checked the fluids.
Gave her a wash, cleaned the wheel wells, hit the paint with a second coat of spray wax and waxed the wheels for good measure.
Looking good for the weekend. Always feels good to have a clean truck sitting in the driveway.
OHSIXX
Milwaukee
Or garage in my case...but so true!! :buffer: Mine is actually still pretty clean considering its December in the Midwest. Been too cold to detail but may fire up the heater in the garage....you have no idea what that is like though.
Just filled her up alst night with 93 at $2.49 a gallon.
@Fosscore
Fosscore
@Fosscore
Heater? haha Only to check it in the house or warm the kids up on the way to school one random morning, maybe once or twice per year. I actually had to crank my a/c down a notch in the house as the humidity this week has been over 80% and temps in the low 80s.
Wish I had a garage....but at least I do have a carport and was sweating last night polishing away. But it was worth it to drive it down the road to work today. I kicked the wife's Honda Odyssey out into the driveway after summer. Ooops!!
She needs a top up of 93 too @ $2.99/gallon.
@OHSIXX
randres33
St. Petersburg, FL
Swapped out my fogs with a set of Rigid Industries Amber led cubes.
Tehboogyman
Put a Class III hitch on. I'm gonna be moving in a couple months and gonna have to tow my '79 C10 so trying to get the Tahoe ready to go.
jcevans7
Friendswood, TX
Changed out a connector for the oil line cooler that had a leak. It was the dang c clip on the radiator connecting the oil line. Switched it out finally. Still a booger to put in but moving the fan shroud knocked the cap to the radiator reservoir off. Spe t 40 min trying to find it. Hiding in the engine somewhere. I'll look again tomorrow.
Sent from my SM-N910T using Tapatalk
Fosscore
Nice low rides across the board. That HD hood looks sweet!
WITCH1975
