Esky taillights
bourgeois
I believe there is only 1 wire from oem plug for brakes and blinker. I am not sure but I would hope someone would figure out. I know member Mitchell try putting the Yukon tail lights on and he had the same problem with the brake and blinker
luigasca
luigasca
So how did the oem originals know to separate the blinker and the brake light can it be program related? They should have just made the Tahoe and yukon the same.
Sent from my SAMSUNG-SM-N910A using Tapatalk
bourgeois
I agree.
on the factory lights, the brake and blinker are the same light. Im sure there is a way. I just need to sit and think and play with it
luigasca
luigasca
maybe this can help. The left is the aftermarket and right is oem. Is ur oem the same as mine?
luigasca
luigasca
Here is video on how the light work. First I unlock my vehicle then I hit the lock button twice and right after remote start it. 5k reverse lights. Loving the lights. Alot of attention I been getting by alot of people.
bourgeois
Factory plug is on the top. After market is on the bottom
My wires on the factory side look the same, but the aftermarket light plug is different.
Would anyone know if this would be the problem with the tail lights not working correctly?
luigasca
luigasca
Unique look bro.. [emoji106][emoji106][emoji108][emoji108]
bourgeois
Ricky. Does the lights work like a Cadillac? Or does your blinker lights come on with your led brake lights?
Can you send a video of the lights working?
hamd1719
Are reverse LED already installed or its a aftermarket led
Sent from my SM-N920C using Tapatalk
luigasca
luigasca
They come with the lights. Installed.
bourgeois
I have the same issue with the brake light and blinkers. They are fine on the yukons, but on the Tahoes the brakes and blinkers work on the same wires. So they both come on each other.
I wish it would work correctly.
Richystahoe
Hanover park, IL
I don't know what your trying to say. When Im braking and turning it is still blinking, isnt that how they are suppose to work? Please elaborate.
luigasca
luigasca
The long brake red light supposed to turn on by its self. The blinker/ turn signal turns on when you hit the brake. The turn signal supposed to stay off when you brake.
bourgeois
the correct way:
-Long LED light is for the BRAKE LIGHTS only
-small clear strip on the inside of the brake lights is for TURN SIGNAL only
they do not light up at the same time
Tahoe way:
-when the brakes are pressed, the long LED and the small clear strip light up.
-when the blinker Is on, the long LED and the small clear strip blink .
they light up for both functions.
The problem is, Tahoe uses the same wire/light for brakes and blinker. Were as the Yukon has a separate wire/light for the brake and blinker.
johnsonwillie199
