Deephaven
I spit on mine and called it a filthy *****. Then I felt bad so i wired my DRL's and lower turn signals next to my fogs to come on with my headlights. They also still come on during the day when ever my DRL's feel its sunny out. I also changed everything to LED. Now it looks like a clean *****.
I want to see the LED's!
Marioski
IL
Replaced the 12v with the usb factory usb receptacle for a cleaner look. Nothing major.
Bruizza
Yep they are my winter wheels. I also added a dual usb port to my dash. I was able to do dual since I have replaced the HU. Unfortunately I needed another right angle usb connector but all the stores were closed so I have to actually hook up the 2nd port still.
Joew311
TX
Is this just a charging port or does it connect to the HU for the iPod control?
Marioski
IL
Mines an 07 (Avalanche LTZ). So it's just a charging port.
Joew311
TX
Oh awesome, do you have a p/n by chance? I've been wanting to do this too, but all I could find were the connection ports for the HU and that's already in the console.
Marioski
IL
I do. Are you looking for the p/n for the actual gm USB piece and trim? The way I have it done is I just pulled out the factory 12 volt plug and left that pugged in, stuck in a 2.0 amp USB adapter and then a short USB cable that plugs into the gm part (mini USB). Wrapped that up in electrical tape and there is a open spot right under the hvac controls in the dash where all that tucks away. Easy setup and can revert back to stock when necessary.
Joew311
TX
Sure, send me what you have and I'll take a look at it. Thanks!
Marioski
IL
P/N 20983937 GM USB port cover/chrome trim ring
P/N 2094422 GM USB plug
You can find combos of both of these sold on eBay. That's where I got mine from. Should set you back $30 for both
Been a little busy today as I also got this done. Russell S/S brake lines. These were for a Tahoe, non LTZ. But figures the only difference with an LTZ are the autoride as the brake lines have different brackets to accommodate the arm for the sensor. So a little nip, tuck, modify'ing of the original bracket to work with these lines and viola they fit an LTZ model. Also changed the front calipers with new ones, and some new zinc coated rotors, plus bled all four corners with new fluid. Btw big improvement over my 182k mile factory lines and fluid!
talofa808
Honolulu, HI
Installed the Dorman Carbon Cabin filter, for some reason i thought it would be easy but all i had was a little hand saw and that took forever. but its done.
Bruizza
Found out this morning that when it is wet outside it is extremely easy to break loose the tires now that my headers have been installed. Startled me at first because it was unintentional. Should be interesting to see how things go tomorrow after my BB tune.
Joew311
TX
Does anyone know if the backup cameras with the 6-prong plug labeled "12V" is a 12 volt camera or does it still need a transformer to get to 5 volts?
t.stimpson
finally got these LED tail lights installed. Had to direct wire them but I like how they look.
JML07denali
Had the carpet steam cleaned. They look and smell brand new. Once they dry they will be covered up from front to back with my weathertech's
Joew311
TX
Replaced the interior lights with LED's from superbrightleds.com! These things are amazing! Very white and seem to be very well made.
P/n: 4210-W1-CB: White
ASG-MikeS
