service ride resistor trick? not working
denalliworld
how forum,
I have 2 blown rear oem air ride shocks
I want to bypass the service ride error with resistors and use the oem in the front and some basic shocks in the rear.
I tried the 3.9ohm resistors on each shock but the service ride does not go away.
how do I do the resistor trick correctly?
the front shocks look good and the level sensors on both sides work fine
the air ride compressor turns on when i bypass the relay under the hood
TheAutumnWind
how forum,
unplug the battery.
pull the fuse for the compressor/air ride.
Plug the battery back in.
Enjoy not having the service air ride warning.
D
denalliworld
unplug the battery.
I wanted to keep the fuse in and let the air ride work because the level sensors on the body seem to help with braking.
Does the resistor trick work or not?
You said you have blown rear shocks and those are the only air shocks you have.(The stock ones are also auto damping) The fronts just use an electronic damping system but no air. The service ride control light can be on for any number of reasons but in your case I'd say it's because of the blown rear shocks. It the ride height sensors see its sitting low, the compressor is supposed to come on and air up the rear to level it. Also, if the compressor or the suspension computer or auto damping have a problem the light comes on. The resistors are for when you change to non-auto-damping aftermarket shocks either front or rear. They take the place of the electronic damping but that's all. They won't fix anything else.
D
denalliworld
so If i put 3.9ohm resistor in the non dampening rear shocks, the service air ride light will not come on?
You have to either repair the compressor and put in air shocks from someone like Arnott or disable the system. The Arnotts come with bypass resistors. You might want to pay a shop to read the codes and see why the light is on. The resistors are mainly used for the fronts since you can get several different shocks for them.
vegard norway
Hi all.i have tried to Get rid off src Message for months ..disconected - on battery and romoved fuse rtd.message gone.!.thank you so all mutch.!!.
Ihaveatahoetoo
