Rivet fender flares
Mondo
Can anyone help me find rivet style fender flares.
I don't want actual rivet flares, just want a quick simple install with the rivet look. As in the attached photo.
01Konvict
Boats n Hoes
Raleigh/SML
Bushwacker doesn't list those being made for the Yukon XL and Surburbans but I think that Denali has them from a truck body. Compare the body lines of a 1500 truck to the XL body. I know you have to remove the stock body moldings on the rear.
YukonXL04
The Riverboat
Arlington, TX
I would be curious if the Avalanche rear flare would fit.
The front from a sierra would be fine as they use the same fender, I wonder if the rear of a avalanche stems from a burb or XL
Mondo
Mondo
The very small rear molding behind the rear wheel is the only one id have to remove but instead i plan on simply moving it a few inches to clear the flares but keep the look.
---------- Post added at 12:57 AM ---------- Previous post was at 12:55 AM ----------
So pretty much I have to either rig one from/for other trucks to work. Their is none made for the XL specifically.
01Konvict
Boats n Hoes
Raleigh/SML
I prefer the side and rear moldings off with this style off flare. I have seen a regular Yukon with Tahoe flares cut to fit the moldings. It looked ok but still think its too busy on the sides for all of it. Yes you will have to evaluate if the Avalanche or 1500 body is closer to the lines of the Yukon XL. I would expect the Avalanche would be closer if not the same. It's easy to fit them as its only plastic shaving and some rubber trim moldings.
01Konvict
Boats n Hoes
Raleigh/SML
Saw that Lund and Smittybuilt are that rivet style fender flares. Do some research on those brands to see if they make one for a surburban.
Mondo
Mondo
Thank you my friend smittybilt has the M1 Flares that are exactly what im looking for.
http://www.smittybilt.com/m1flares#prettyPhoto
Perfect for when I get my 2" Wheel spacers.
Scratch that they dont make for my year or any for gmc for that. And only 07+ chevy so the search continues
ProfeZZor X
High Country
I've been looking for a set of wide fender flares for my 22' Yukon AT4, and I even consider test fitting one of those Bushwackers and having a shop modifying them to fit for my body style.
JasonW4141
