Carpet replacement in 2006 Yukon XL
cbodnar
Hi guys, new to this forum. Just picked up a 2006 Yukon XL. Only problem with it is a slight smell of gas which I'm pretty sure is in the carpets. Had it back to the dealer and not really having much luck with that. So thinking about replacing the carpets myself. Never done anything like that before. Wondering if anyone has some good links for doing this project. Diagrams, tools needed, videos would be great. Any and all info will be welcomed.
Thanks for the help
Chris
Copper&Black
Super easy if you order a carpet kit molded specifically to our trucks. There is no holes cut in these type of kits so what you will need to do is pull the old carpet, lay it on top of the new carpet, and Mark/Cut the holes out with a Razor. Removing the seats is pretty easy. Just remove the bolts and nuts holding the brackets down, disconnect any power from the clips and remove. Some plastic will need to be removed as well. Like the plastic pieces at the bottom of the door opening, and the areas over the rear wheel wells. Just take your time pulling these off, pull in the area of every clip holding the panel and work your way down the piece. The rear cargo net holder/bolt will also need to be removed for the rear panels to come out. Replace old carpet for the new one and reinstall.
I had the seats and carpet out of my truck in less than 30 mins. You will need Metric Deep sockets and ratchet, Chan locks or something to grip the net holder bolt, Razor to cut the new carpet, and your hands to pull the trim out.
Good Luck
9CZ71Denali
Albany, NY
Is there a carpet kit available for the 07's and beyond? I have an 07 and would love to put black carpet in it...
preston
Humble, TX
I have been looking for one for the 07+ as well without much luck other than a factory one from the dealer.
Anyone know if the NBS year carpet kits are the same as the NNBS? I know the floor mats are cut to pretty much the same shape from looking at them.
Eickybobby5050
