Just discovered Im missing a part of my IFS, Help Id'ing the part
owl_93
Just taking a look under the front end a moment ago and noticed im missing a rod that connects my lower a-arm and a bar that connects to the other side. I don't know a ton about IFS. Can someone ID the missing part please?
Here is the intact side:
Here is the side with the rod missing:
yates ™
Resident Apple hater
Iowa
May want to find longer adjustable ones, with your front end stretched as far as it is they will more than likely continue to break.
owl_93
owl_93
Thanks. Any suggestions on brand?
Sent from my Galaxy Note 4 via Tapatalk for Android
yates ™
Iowa
Sadly I don't know of any but I also have never looked for them :crazy: I know they make them for lowered vehicles and sure they also do for lifted applications. The other choice would be make a small spacer to move the sway bar down a bit.
owl_93
owl_93
Am I damaging anything by driving without 1?
ezdaar
Chat Troll
Redneck central, Aka Houston
no, damage, just will corner like pooooo
since you off road and are now busting endlinks, look to the quick disconnect type.
Disconnecting sway bar really helps offroading.
owl_93
owl_93
I posted on your other post about that problem - its prob the right size, try jacking up your lower control arm and threading the bolt up top.... I just did these. - Ill post up a video here in a sec
https://www.youtube.com/watch?v=B515N144WOQ
or
https://www.youtube.com/watch?v=nyapHaiXILI
Thanks for the videos and the help man. I really appreciate it. I'm gonna try to get that sucker installed after class and work today
Coatwolf
Eastern Virginia
No Problem - those are one of those things that can be a little tricky at first sight. Just holler if you need anything
X-ray Nerd
