coil over conversion installed
digitalfiend
Expert Overthinker
San Antonio, TX
So when will you be sending out some bushings for me & Atomic to try out?
Based on iregret's latest update it looks like a compromise between his bushings and my beefy bushings would work fine. If you or Atomic can get me the measurement to make the diameter of the bushing and washer then I'll start after I pick up some steel to make the washers from. I think the washers can be 2" in diameter and the bushings will be 1.75 in diameter, but I don't have a set of his uppers to test against.
Atomic
Huntsville, AL
I gave my required measurements earlier I think. 1.25" max washer diameter for mine, and bushing of the same size probably. I already have washers.
digitalfiend
Expert Overthinker
San Antonio, TX
I lost that detail in the mix of all these threads when they were active, thanks for reposting it. :)
I'll churn out a set of washers for you with an OD of 1.0" (0.25" smaller than the washer) for you then, which is the guideline I've been using for my other setups. You've got a PM.
Tahoewhat
Ballin' on a Budget
TX
Yeah, our threads have kind of died, not much really to keep reporting anymore. I need to update mine, just have been really busy with life and school.
Glad to see his bushings are holding up still as well.
Tahoewhat
Ballin' on a Budget
TX
Craig - Hows it going w/ the coil overs?
Still got them in or did you revert back?
04blackout
04blackout
I hate it. Ordered up everything I need to go back up and it all should be in by monday... gonna be sitting on keys and spacers, bilstein 5100's, and 285/70/17 mud claws wrapped around 17x9 v-tec raptor wheels
It sucks bc I absolutely LOVE the look, but the ride is just plain horrible on anything other than perfect roads. I'm also not trying to go through another winter being super paranoid of all the nasty potholes in town. Should have it all swapped out next wknd
Tahoewhat
Ballin' on a Budget
TX
oohhhh..
Are you lifting it? 17's Did you try it w/ smaller wheels? Ordered all the parts is what got me. Did you sell the tbars or something?
Wonder why you and billy's ride quality is so bad. Mine still rides like a lowered truck, but not bad enough for me to go back to tbars.
Sucks to hear though, but i understand. If mine was that bad i would of been swapped out already.
Hope you get your ride quality back.
Guess im the only one again w/ coil overs.
04blackout
04blackout
oohhhh..
You may not think it's as bad as I do, but I've never had a lowered truck before so it's a whole new experience for me. I gave it a solid 2yrs but I just can't do it anymore. Its a combination of the whole package, bad ride, bottoms out all the time, tires get into the fenders like every day, potholes can ruin my whole day...
Didnt sell T bars, but I did sell the stock coils and got rid of sway bar links... basically had to buy sway bar links, coils, bilsteins, lift keys, spacers, tires and wheels. I got about $1450 in everything bc I found a set of almost new tires for $500. Guy bought them and after 2k miles decided he didn't like the noise anymore
I'll have a barely used set of QA1 coilovers and adjustable shocks for sale real cheap, real soon:chair:
Tahoewhat
Ballin' on a Budget
TX
Ah... all makes sense trust me, we are all different. Mine has been lowered basically since i got it and is the first SUV i have ever had. So being up high felt weird. lol.
Sounds like your lifting now, higher than stock. Thats my next plan maybe.
If you had the longer shocks i would buy them from you, but all have the same ones i do. Im sure if you post them you will sell them. Lots of interest about this.
Either way, good luck with your ride and hope you get it all sorted out and back to the ride you want.
04blackout
04blackout
Why not design a lift around the coilover setup?
ATM, cost... trying to keep it as cheap as possible for now, leaving the option to return to coil overs in the future
still trying to sell a house, so with 2 mortgage payments, every little bit counts
04blackout
04blackout
been awhile, had alot of stuff going on... but finally got it all put together and dialed in, even got my tow mirrors on :)
Tahoewhat
Ballin' on a Budget
TX
Like the sig pic. Completely different animal now.
What exactly did you end up buying for the lift? I am really contemplating lifting. Just want a change.
How high is your lift?
Pm me if you want.
Bomba02
Ride looks sick with the tow mirrors. I'm digging it! You need some roof running lights and bam, she'll looks sick!
04blackout
04blackout
Pm me if you want.
eBay keys and 2" rear spacers on stock rear coils, bilstein 5100 shocks all around
idk what the exact lift is, but the rear fenders are at 40.5" on 33's, front is a little lower... gotta have some rake for towing/hauling heavy loads
HeavyHoe03
