6.5 to 7" springs
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Let me know bro
no prob. These springs will be the lowest by far you will be able to go. Im dealing with a fine line of looking cool/riding well.
---------- Post added at 09:17 PM ---------- Previous post was at 08:48 PM ----------
I Should have the set here tomorrow. I will post some pics up and double check the ID to make sure the 60742 airlift bags will work
LoHoe
sounds good man.. just let me know whats going on
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
wife just called new springs just showed up.
Chevy*808*
Are you going to post pic of the spring ?
Didn't your post stated that they took out a full coil ??
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
the spring one loop was taken out so it would not hit eachother on compression.
Pachanga02
Ny
Tony just to be clear will you need to notch the rear to fit these or no?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
What im trying to dobis get low enough where it still has travel and rides good with helper bags. You will need to run a shorter bumpstop on axle and prob notch out upper cross member for the panhard bar mount on axle. Or trim down the mount on axle. Ill see how feedback goes then can decide what needs to be done
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
springs were already sent out to first tester
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
im waiting for tester to get back to me. due to new spring having less coils the helper bags should tow better since they have more area to sqeeze into.
LoHoe
nice! will they send before and after pics?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
my cut current springs rode better then these. Im going to be doing another spring design
Buford bubba
