YukonXL04
The Riverboat
Arlington, TX
Bought the materials to complete a power steering/hydroboost flush and a differential service (fluid and gasket). Also going to clear my wife's headlights by sanding, polishing, and clearcoating. Going to be a fun weekend!
Hey, When doing the headlights, which clearcoat are you going to use?
Toyfare
Jackson, MS
I'm just going to use regular Valspar spray paint clear coat. The lights are in rough shape and I'm not worried about it not lasting. The car is nearly 13 years old (Pontiac Bonneville). I'll post before and after pics on Saturday.
Bomba02
didn't do anything but put it to work a little last night.
jdpber
GOLD MEMBER
The America
Today I took the rear brakes and rotors off to adjust the parking brakes. And **** one pad fell off the retainer ring. So off tot he store for a new set of pads. $48. Hour and 15 minutes total for wheels down to wheels down. The peddle used to go to the floor. Now the brake engages before the good latch. I am happy.
02 Burb
California
Cleaned every nook and cranny with sand everywhere. Finally the found the cause of a rattling in the dash and fixed it. Remounted the stock(******) jack/tools and air compressor in the back compartment.
Rickz04Yuk
Cali (South Bay)
What was the rattling noise? I'm having the same issue
---------- Post added at 01:41 AM ---------- Previous post was at 01:39 AM ----------
Took the beast to the Drive-In for the first time
Glad the battery didn't poop out on me with the radio on for both movies
02 Burb
California
The rattling noise was my fault, when i removed the onstar on the dash i left the plug hanging in the dash unsecured which caused it to bang into everything. i just used some mounting tape to secure it. I also made the glove compartment latch a little more sturdy, because that moved around a bit too.
NeverSatisfied
eBay Baller
Wichita, Kansas
Just put some brand new 285/45/22s on the Tahoe. Got a 8" piece of thick wire went threw the top and out the sidewall of one tire. So just went ahead and got 4 new ones for a hell of a deal
Yuko04
"SquareBODluvr"
MN
Put 200 miles on it. Pulled the RZR to BlackRiver Falls Wi to hit the trails.[emoji41]
SUBLETTKUSTOMZ
Toyfare
Jackson, MS
Power steering and hydroboost flush was a breeze. Differential fluid change was easy, but I accidentally screwed up the gasket I bought so I made one with Permatex Grey. Apparently I did it wrong because I woke up the next morning with my diff leaking. Did some research online and bought Permatex Red (high heat) and followed the directions to the "T". I ended up botching the first attempt at putting the cover on, so I had to clean everything off and try again. I am letting the truck sit overnight before I drive it to work tomorrow to let everything cure.
nhoj_yelbom
Pensacola, FL
They have the mounting cage already on, but there is a lot of play in the hole that the locking pin goes through. This weekend I'm going to pull them off and see if I can swap the stock cage. That would be awesome if it's possible. I also need to pull up to a wall and make sure both lights are level.
stock cage will swap over perfect
---------- Post added at 11:58 PM ---------- Previous post was at 11:56 PM ----------
That sucks to hear! You have a very clean truck!
thanks, it needs a complete paintjob and a new trans. interior and engine good though!
Jewel or Jalopy
Portland, ORE
Any suggestions on what brand..... Delco or Desnco????
Go Denso, I'm almost positive they're OEM for our trucks. I was an application engineer for Denso back in 1997 working on the 2000 trucks, and the Denso O2 sensors were way better than Delco. So much better they named Denso supplier of the year due to better quality, lower price, and reduced warranty costs.
Hodmjstone
