rob3827
philadelphia, pa
On Sunday 20th of July drove from Philly to Silver Spring Maryland to see my daughter and her new apartment. Today, I changed out the intake manifold gasket on my 2001 Suburban LT 5.3. I used the Fel Pro gasket set. truck is running like a top.
Rivieraracing
Ordered a set of new front door pins for my drivers door today, hoping it has the same fixing effect like it did for NCTyphoonKid's a pillar air noise when driving! Mine actually have some slop, just wish I'd bought them when I first saw them for $2 cheaper than I paid today!
NCTyphoonKid
Trinity, NC
Hope it works for you definitely post the outcome of whether they help with yours or not. Mine are still doing good and took it on a 3 and an half hour vacation trip two weeks ago and so far so good.
---------- Post added at 11:32 PM ---------- Previous post was at 11:31 PM ----------
took the wiper arms off to repaint since they were looking pretty bad and wound up cleaning the whole thing
indigent
Central Texas
Guess I've got a job for this weekend..... Need to replace the B1-S1 O2 Sensor.....
Any tips or tricks to make the job easier or less of a pain in the a$$......
Rivieraracing
Yeah, I will post up results for sure! Won't get them until wednesday but probably won't install them till Monday! I'm not totally surprised but I did have some slop in the door so it would make some sense for the wind noise!
---------- Post added at 09:42 PM ---------- Previous post was at 09:41 PM ----------
Yeah, get yourself an O2 sensor socket and also spray a bit of penetrating oil a few times a day on the O2 sensor where is screws into the piping for a few days before you do the work!
Rickz04Yuk
Cali (South Bay)
I Plasti Dipped my Hitch to give it a younger look to it also brought all my exterior trim back to black running boards and rear bumper look amazing now
Oh I almost forgot I took out my radio to reroute the Isimple wiring that was done incorrectly to my surprise I found the gateway had an Aux Cable as well OH YEAH
dawgofnate
Houston
I've been happy with my isimple. One of these days I'll get the dip out too.
indigent
Central Texas
Any suggestions on what brand..... Delco or Desnco????
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Or hit them with a propane torch around the bung till they glow and then hit them with the PB after they cool a little if they're really stubborn. The heat expands the threads in the bung away from the sensor threads breaking away the corrosion. The PB seeps into the already broken free threads and lubes them up.
Stam2000
Finally had time to do NNBS brake upgrade
Blue2002Tahoe
Replaced the factory sub with kicker 40cws82. For all the people who don't install huge subs and boxes in their tahoe I'd definitely recommend replacing with this sub
Toyfare
Jackson, MS
Bought the materials to complete a power steering/hydroboost flush and a differential service (fluid and gasket). Also going to clear my wife's headlights by sanding, polishing, and clearcoating. Going to be a fun weekend!
Korbin_A
