2015 GMC 20-22-24 inch replica wheels
MarkD51
Sheboygan Wisconsin
Great wheel/tire choice Mark...should look hella nice!!
I'm running the Nitto NT421Q's as well.....love them...
Just a short update for now, my puter is being repaired, so no pics for now, but some comments.
I installed the Wheels-Tires yesterday morning all went smoothly, and am very happy. The wheels do tuck a bit better than my old, there's clearance galore with the 285/45-22" 421Q Nitto. Both height-wise, and width-wise, all checked from lock to lock.
I can now understand why Tony said a 2/2 slam would look good and he's correct, man know's what he's talking about.
I might ever so slightly de-crank my front torsion bars, perhaps dropping another 5/8"-3/4" up front because right now I'm looking like my truck has been "leveled". I'll also drop PSI on my Firestone Ride Rite Air Bags in the rear maybe down to about 15-20 psi. Was running about 35psi unloaded.
Torqued all wheel lugs at 130 ft lbs. I'll of course check all again soon.
The ride is great! I've set tires pressures at 40psi, all seems well with that, the tires are smooth, quiet, and from within the cab, I barely notice any difference in ride firmness from before the swap.
Steering feels great, truck runs straight and true. No notciable loss of braking, seems about the same. Sure, I might've lost a little braking distance, considering I've gained about 22 lbs of weight per corner versus the 16's with 275/70-16 Michelin LTX.
Truck looks really great.
Again, I'll post some pics for you folks ASAP. Mark
Goodinblack
I Like Tacos
Dirty South
This reads as blah blah blah to everyone here.
Pictures. Meow.
Hahahhahahaa
MarkD51
Sheboygan Wisconsin
OK Folks, here's a few pics of my '97 Hoe as promised.
Sorry if the file sizes are sort of large.
Pockets
West Ga
Looks great... think I would try and bring the whole ride height down if mine.
Goodinblack
I Like Tacos
Dirty South
Looks great Mark !!!!
---------- Post added at 11:39 PM ---------- Previous post was at 11:01 PM ----------
22 on obs......... huge
22 on KXXX.......... tiny
MarkD51
Sheboygan Wisconsin
I'll try dropping about maybe 3/4" up front by de-cranking the T-Bar Keys a bit, and drop some of that air in the rear.
While it doesn't look it, I've gone up in tire size from 31.25" from the old Michelins, to an even 32" with the Nittos. Went ahead and re-did tire size a few days ago with my Hypertech Programmer to the new correct 32" diameter.
I probably also could've gotten away with 305/40-22 with no problems, but the 421Q Nitto is unavailable in that size.
This wheel, with its +31 offset does appear to tuck a bit better than my wheel-tire combo of old.
felixgun
Lafayette, LA
Color match the bumper and handles and everything else thats black. Then lower. Rims look good though!
MarkD51
Sheboygan Wisconsin
needs an alignment, too much positive camber in the left front.
Yes, it does look that way from one of the pics I posted, and I don't normally notice such otherwise in real life.
Possible a "Fisheye Effect" from the camera lens, or parked on slightly uneven ground? Or a combo of the two?
But while we're on this topic of Camber Angle-Alignment, does the degree of Torsion Bar Cranking and Tension effect Camber? Or no?
Thanks, Mark
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Lower you go the more negative camber you get
Goodinblack
I Like Tacos
Dirty South
Thanks, Mark
Yes it does
---------- Post added at 12:58 PM ---------- Previous post was at 12:55 PM ----------
What Tony said
They way we were taught in ASEP was
"You P Out Back"
Like piss out back
So the tire moves out on the top..... that's positive (P) Camber
The tire leans back........ that's positive (P) Caster
MarkD51
Sheboygan Wisconsin
"Here's to swimmin with bow-legged wimmin"! LOL
So, the possbile adjustment of the one Torsion Bar some months back could've given me a "bow legged" effect? Ah Ha, hunch was right.
Odd thing was, I never touched the Driver's Side Torsion Key, only the Passenger side, as it was drooping about an inch lower.
And as I slowly cranked the passenger side, and continued to take measurements at both sides, the driver's side was mysteriously rising as well somewhat. Height was not staying the same.
Is this possible one side effecting the other?
While adjusting I did bounce on the front every time a small adjustment was made and even took a short 5 minute ride to let the front settle out.
Possible this weekend I'll toy with the front some, easy enough to do, not hard, just take a little back and forth measuring, and tinkering with Jack, Breaker Bar, and Socket.
MarkD51
Sheboygan Wisconsin
Truck is looking good! Needs more low but I'm digging the way it looks as is.
Here's another shot, not so sure it looks "bowlegged" I this pic?
None the less, I eyeballed the truck this afternoon a bit, and agree I might have a slight positive camber mal-alignment on the driver's side.
I'd rather treat such myself, rather than trusting the turds here who I won't trust a lawnmower to, and will most likely mar a new set of wheels with their wonderful crap machines, and lazy-ass work ethic in this "land of crap".
I'm better at a "seat of he pants" alignment than they are with their high tech BS machines. If I get 5K less mileage out of the tires, this doesn't worry me. What worries me is BS Artist Goons taking me for money, and accomplishing nada.
MarkD51
Sheboygan Wisconsin
Here's another shot, not so sure it looks so "bowlegged" in this pic?
I'd rather treat such myself, rather than trusting the turds here who I won't trust a lawnmower to, and will most likely mar a new set of wheels with their wonderful machines and a seeming poor work ethic here.
I might be better at a "seat of the pants" alignment, and my eye, than they are with their high tech malarky. If I get 5K less mileage out of these tires, this doesn't worry-bother me that much. Pulling from incorrect toe in would be a larger concern but haven't noted such. Roads aren't exactly the greatest here.
Ooops, sorry for the two porta crappers seen in the background in this pic!
MarkD51
Sheboygan Wisconsin
At the height my front end is at currently, one perhaps could also assume-say the same slight positive camber exists at both wheels. To tell the truth, no alignment of any sort has ever been done on this truck since new. This is the third set of tires-wheels on this 39K truck. The original alu wheels BFG tires currently are residing 1200 miles away in my father's basement. They had about 4-5K on them when they came off.
Durobans
